"ingegnere":2zcbfh0o" said:
Hi, 1. Can we do nonlinear inelastic analysis in İdecad 7? As far as I understand, it can only calculate according to linear elastic methods. It is done by the articles 7.5.1.1 and 7.5.1.2 in the regulation. If my building is higher than 25 meters, can I use performance analysis with mode combination method (linear elastic calculation)? Or should we use one of the linear inelastic calculation methods (incremental static pushover analysis). My second question is that in the performance analysis of the idecad 7.020 demo version, there are embrittlements due to the shear force of the curtains. In this case, even when I increase the amount of horizontal reinforcement, the report does not show any change. Is it because it's a demo? I was able to do this in the full version. Thanks in advance and good work to everyone.
Hello, *Performance evaluation of existing structures in the program can be done with the Linear Elastic Calculation Method. * As stated in Article 7.5, calculations can be made according to the mode combination method in buildings higher than 25 meters. *There is no difference between the demo version and the licensed version, except for output restrictions. If the member capacity does not increase when the shear lateral reinforcement is increased, "Reinforcement corrosion" and "Insufficient clamping Length Yield stress factor" can be zero or close to zero in the Wall properties/Performance analysis tab. If you add the project, more detailed information can be given. Good work
