"epoxi":210ce7x2" said:but I also know that there is a belief that superstructure interactive solution usually fails on a continuous basis. Except for the rafter raft flooring, the superstructure interactive solution can be made error-free and correctly.For the superstructure interactive solution, both continuous foundation and beamless raft systems can be used.Can you add an error-prone project.
Do I have any colleagues who can answer my question?"epoxi":25pqplp0" said:thanks for your comments. It is not accepted, so how would it be appropriate not to meet this requirement, good day from an engineer's perspective
Does it make any sense to you? I do not know, but I will give an answer: The program does not give a negative warning in the output, although it warns some errors. For example, you can also make columns 20/20. Analyze and see, it does not give an error in the output. But it warns you in geometry control. You can think of it as "are you sure you do". For example, you may be doing performance analysis or risky construction. Allows data entry but warns you on entry. Yet another example, you can insert a column at the end of the cantilever beam."epoxi":1tn0fi0j" said:Do I have colleagues who can answer my question?"epoxi":1tn0fi0j" said:thanks for your comments. However, this warning is given in the geometry control in the program, but it is not considered as an error in the report. So how would it be appropriate not to meet this requirement, good day from an engineer's perspective
Hello, There is no possibility to define curvilinear curtains as a single piece in the program. You can edit the detail drawings using 2D possibilities. , you can use the tile edge command to create split panels using the joint points."gunner":3efg48ws" said:hello. I have a project with an elliptical form. I tried to enter the foundation in line with this form, but I can't use the tiling line as curved. While on the architectural plan, the same problem exists on curtains. I can't make curved curtains directly. bow I thought I got rid of this problem by using the 'convert to panel' command by drawing it, but when I looked at the panel details, the drawings were all intertwined...
"NYILMAZ":2qf6tmxp" said:I don't know if it makes sense to you, but I'll give you an answer: Although the program warns some errors, it does not give a negative warning in the output. For example, you can make the columns 20/20. Analyze and see, it will not give any errors in the output. But it warns you in the geometry control. You can think of it as "are you sure you do"[/b]. For example, you may be doing performance analysis or risky construction. It allows data entry but warns you on entry. Yet another example cantilever beam You can enter a colon at the end of the n. Shouldn't he also consider the economy?"epoxi":2qf6tmxp" said:Do I have colleagues who can answer my question?"epoxi":2qf6tmxp" said:Thanks for your comments. He says it cannot be more than 10. But in the program, this warning is given only in the geometry control, but it is not considered as an error in the report, so how would it be appropriate not to meet this requirement, good day from an engineer's perspective
Hello, Unfortunately, your project file cannot be recovered."izmirlimuhendis":1g2q8o5a" said:it gives a "file corrupted CRC Check" warning when opening the file I wonder is there a way to recover the file linkYou do not have permission to view link Log in or register now.
Buildings to be built in earthquake zones Chapter 7 of the regulation is devoted to the evaluation and strengthening of existing buildings. Article 7.2 of this chapter explains how to collect information from buildings. I wish you a good work. Şükrü Şahin İnş.eng."izmirlimuhendis":w4zgmhnq" said:For example, in retrofit projects, there are 50 beams on the floor and if 10 of them are equipped with x-ray and other methods, how do we determine the reinforcement of the other 40. Sent from my iPhone using Tapatalk
Beta coefficient, dynamic analysis report, "dynamic analysis login information" You can see it in the "earthquake parameters" table in the report."sereze":rwbbk5dv" said:Where can we see whether the beta was 0.8 or 0.9 according to item 2.8.5? Do we have a chance to enter the beta ourselves?
When you define beam or column, joint points are created automatically. If you write the purpose of asking the question, we can write a more accurate answer for the situation you want to do."civilengineer.v":vhetvn7k" said:can we define the joint points of columns and beams ourselves?
First of all, let me state that I am a demo user."HakanŞahin":3gofom0g" said:When you define beam or column, joint points are created automatically. If you write the purpose of asking the question, we can write a more accurate answer for the situation you want to do."civilengineer.v":3gofom0g" said:can we define the joint points of columns and beams ourselves?
