Levent Özpak
Active Member
"hakan_sb":3jx8sbct" said:how can I model the curtain modeling at the end elevation:3.50 and the other end is 2.50 inclined curtain in the project I am doing? It is not possible to define the object.
Hello Mr. Levent, S**4-Cad is used as local software in the project office where I have been working for 2.5 years. I know the advantages and disadvantages of the software very well. I have been following ideCAD since 2008. I think it has made quite a splash with Version 6 and has gotten to a very good position in Version 7. For the last few years, I find myself defending ideCAD in every environment. My friends sometimes hang around saying that if ideCAD officials see you, they will immediately hire you. That's how much. But I can't understand why you don't put some things in the software. Now the calculation algorithm or model interface does not allow mur, I don't know. For example; 1) Why can't we give different jeans to the two ends of the curtain? Mesh algorithm problem? 2) After the analysis, why can't I click on an element from the plan and see the element results and the reinforcement dialog? Especially when I want to change the beam reinforcements manually, when I go to the beam tab from the reinforced concrete menu, beam names are written on the page that opens. In other words, it is necessary to find the name in the plan first and then change it from that table. Isn't that difficult for you? Or is there a different way? 3) Why are there no floors in the tree menu on the left? Switching between floors by right-clicking on the page information bar is very awkward and useless. 4) After the analysis, displaying the elements with insufficient cross-sections by flashing in the 3D window speeds up the work. Are you considering introducing such a feature? My intention is for the software to get better. I already know that ideCAD is superior to its competitors in dozens of different areas. But these are the first features that an engineer like me, who uses different software in his professional business life, will look for when he decides to use ideCAD. With love."Levent Özpak":b41d3hrl" said:The program does not have the possibility to define panel objects with different heights on the left and right ends."hakan_sb":b41d3hrl" said:how can I model the curtain modeling required at the end elevation:3.50 and 2.50 side sloped curtain modeling in the project I am currently doing? ff. edr.
Technically there is no problem with giving different elevations to the two ends of the curtain, but it is not on the priority list at the moment ..."MaFiAMaX":214tfjaj" said:1) Why can't we give the two ends of the curtain different elevation? Is the mesh algorithm a problem?
When you select any element in the program and enter the reinforced concrete dialog, only the relevant element appears in the dialog. I think this opportunity will speed up your transactions."MaFiAMaX":214tfjaj" said:2) Why can't I click on an element from the plan after analysis and see the element results and the reinforcement dialog? Especially when I want to change the beam reinforcements manually, when I go to the beam tab from the reinforced concrete menu, beam names are written on the page that opens. In other words, it is necessary to find the name in the plan first and then change it from that table. Isn't that difficult for you? Or is there a different way?
This option is currently available in the program. In order for it to appear in the building tree, it is necessary to exit the Floor General Settings dialog after the project is opened and click OK to exit the dialog"MaFiAMaX":214tfjaj" said:3) Why are there no floors in the tree menu on the left. Right-clicking on the page information bar is very awkward and useless to switch between floors.
Such a feature is planned to be added to the program in version 8. Good work"MaFiAMaX":214tfjaj" said:4) After the analysis, displaying the elements with insufficient cross-section by flashing in the 3D window speeds up the work. Are you considering introducing such a feature?
"free":3p293jw0" said:sir, I can't open the file I saved as .dxf in autocad in idecad. I would appreciate your help. If your goal is to create axis, column, beam elements, you can use the Tools/2D Architectural Project Read command, however, the elements must be defined in their own layers in order to use this command fully.
The problem may be due to the windows language region settings not being in Turkish. Change it so that it does not exceed 8 characters and not contain Turkish characters (For example, make a1.dxf) If the file is being imported, the problem is caused by Turkish characters. You can check the link below to edit the Windows language and region settings in Turkish."free":sod15w4u" said:I followed the instructions you said sir, but it says can't open file, I couldn't solve the problem no matter how hard I tried. Thanks in advance for your help
"free":2o7oczwt" said:sir, I also fixed the windows language region settings, but it didn't work, before that I had ide 5 on my computer, and when I installed it later, it gave an error. add it to the message, let's see if it opens for us...
Upload it to the upload sites and give the link. For example, to the site below;"free":1ftns4lr" said:sir, I can't add the dxf file to the site
The Dxf file you added can be imported."free":151gglen" said:http://www.dosya.tc/server14/C0omcy/a1.rar.html I uploaded it sir
Contact us by voice. Let's examine the problem with remote access. tel:0-224 220 67 17"free":3vpt232m" said:so why is it not imported for me, sir?
