Hi. I'm using 7.018. I assigned the "A" hotkey to draw beams, then I realized that I can't draw beams all the time. In general settings, "Continuous drawing mode" is active in the Drawing tab, but I couldn't draw, so I said something is wrong I uninstalled the program 2 times, deleted its old files and reinstalled. In my last installation, I tried to draw by pressing the beam button this time, I could draw continuously. I said the problem was solved, I pressed the hotkey, this time I cannot draw beams continuously with the shortcut key A. After drawing a beam , I have to give a command again. It doesn't work when I try to draw with the hotkey, it happens when I press the Beam button in the menu??? I tried other shortcut keys, it didn't work, and I couldn't see any command other than "Beam" in the shortcut. Am I doing something wrong or is it a program error? Thanks, have a nice day...
