Levent Özpak
Active Member
"windtalker":3peg2j9y" said:Hello There is also a shutdown problem in the following section. When the mode number is set to 50, the porogram is closed during the analysis. There is an incorrect combination that I cannot catch. Is there an easy way to see these errors? Thank youYou do not have permission to view link Log in or register now.
The analysis is completed smoothly in the project you added. How much ram is your computer? (According to the semi-rigid diaphragm option, there must be at least 8 GB of RAM in the analysis. Recommended 16 GB) Otherwise, contact the voice. Let's try to identify the problem by connecting to your computer remotely."Levent Özpak":3peg2j9y" said:....Also, even if the mod number is 60, the analysis is completed.( Your computer's ram may be insufficient.)
