Hello, In the program, as data input beams are given positive elevation, then the columns to which these beams are connected must be given an upper level. In this case, there is no problem with the drawing. In your definition, this drawing problem occurs because the columns are not given an upper level. Good work"sates":cmtnw06f" said:Hakan, I shared this with you because I don't want this drawing deficiency to remain in the program when the reverse beam is made on the top floors, that is, when the column does not continue, in case of parapet it is not a problem.
"MEHMETSIRAY":9cb8pky7" said:LEVENT MAY ALSO DEFINE INCLINED FLOOR, WHEN WE ENTER BEAM AND COLUMNS BY LEVELS, AUTOMATIC FLOORING IS CREATED WHEN WE CREATE A FLOORING TOOL, [INCREDITED FLOORING TOOL] [INCREDITED FLOORING TOOL] QUARELEK quote NEKOREKUE FLOORING? Do you also have problems when you create the bevel tile with the objects[/u] command?
I wrote a reply to your message last week but it was not noticed... Nedim Bey gave the demo links, but I asked again Let me give you..."mc_signal":3s1lkf4l" said:I wonder if the English version 7 demo version is out, I wonder if you said next week on July 12, can I get some information?
"HakanŞahin":3s1lkf4l" said:Good work"mc_signal":3s1lkf4l" said:7 Is there a download link for the .17 or 7.14 English demo version, I wonder if an English civil engineer friend of mine will have it installed for review.
Hello, could you add your related project to your message by writing a step-by-step explanation such as "I am changing the following on this floor, on those floors"?"akeldan":1kz60hva" said:by interfering with the hairpin reinforcements on the balcony console floors according to the calculation axes, I make the 8-gauge reinforcements, but I see that the reinforcements of some of the symmetrical balconies on the floor did not change in the drawing even though I intervened.
If you add your project, we can check it for the accuracy of data entry. We can give accurate answers."illaga":wc17vpc6" said:hi everyone..As a civil engineering student, I was curious about idecad..I had a question..After entering the data and making the analysis, even though it was immediately used for the structure, M in Reinforced Concrete/Beam control, Errors such as As, Br (pursantaj, reinforcement, torsion..) appeared. In order to solve the pursantaj issue, I will either increase the cross section or decrease the amount of reinforcement. no aesthetics.. I'm waiting for your opinions on this subject..Also, there are colors such as red, purple, dark purple in this reinforced concrete/beam menu in unfavorable situations. Best regards..
