ideStatic 7.17 help (F1) menu Continuous baseline offsets[/color]":281nvj9q] Continuous baseline offsets command, Used to change the virtual axis of an existing continuous foundation. The virtual foundation axis is the straight line connecting the nodal points at the two ends of the foundation. Changing the foundation axis means that the misalignment of the foundation is constantly changing. To change the misalignment with the continuous foundation misalignment command after drawing continuous foundations: Change/Object Edit Click the line /Beam-Foundation/Continuous Foundation Misalignment. Drag the mouse cursor over the foundation beam whose offset you want to change. Left-click. The foundation will be selected. Click the right mouse button. The shape of the cursor will change. Click the left mouse button with two dots to determine the axis to which the foundation virtual axis will be moved. Continuously the foundation will be moved on the new axis determined.In this way, when the foundation misalignment is changed, the foundation changes but the location of the joint points does not change. e that; For example, let's change the misalignment of a continuous foundation connected to columns at both ends with the continuous foundation misalignment command. Even if the foundation moves outside of the columns and appears to be disconnected from the columns, its connection with the column will not be broken. If the column joint point is moved with the move node command, it will be seen that the relevant end of the continuous foundation also moves depending on the column movement. (or I can't)
