"HakanŞahin":1sugc92m" said:
"NYILMAZ":1sugc92m" said:
Unable to block revision cloud. (mu?)
Hello Nedim, Is the "block" command you asked about not blocking not active for the Revision cloud?
Yes, it is not active and it does not block when you select the objects that contain the revision cloud and block them.
The mold plan drawing is not created. Hello, I can get all the drawings in the attached project, but I can't get the mold plan. I can't find where is the problem?
"KUBA2009":2p89n9sn" said:
I can import all the drawings in the attached project, but I can't import the mold plan, where is the problem, I couldn't find it ?
Hi, disable the "Master plan settings/Retrieve selected objects option" and get the mold plan. Good work
I briefly shared in the architectural part, but there was no reaction.
"KUBA2009":2nb8zyp9" said:
Cannot calculate the area in ideCAD Wrep 7.016. After clicking the first point, we cannot continue.
Hello, dear concerned. wrep I shared a few problems in the comments and questions section about the use of architecture 7. I think there is no interest there. On 29.05.2012, that is, 21 days ago, I conveyed that a domain account could not be made in wrep, but I guess this problem was not looked at in the new version. Scanning route operations cannot be performed based on the domain account. While another friend of mine is using it. I need to operate with a domain account, scan, command in another project, but I can't.
Hello, I shared a few problems in
"KUBA2009":21ehmf0d" said:
wrep in the comments section about the use of architecture 7, but I think there is no interest there.
All messages are read and the content of the messages is evaluated, regardless of the architectural or static forum. Good work
In version 7.017. After the object is selected, when you press the esc key, the object seems to be selected, and the selection is canceled when the screen is enlarged or reduced. I didn't have such a problem in the old version. What should I do.
"Oznb":23vhfjc6" said:
in version 7.017. After selecting the object, pressing the esc key seems to be selected and the selection is canceled when the screen is zoomed in. I didn't have such a problem in the old version. What should I do. There is no problem. There may be a display problem. Have you made any changes regarding the video card? It may be necessary to update the video card drivers. It may be related to the project settings. For example, you can open a new project with the template project and try it... If the problem is related to the project, you can attach the project file to the message .
"HakanŞahin":1omt3cvn" said:
Hi, I shared a few problems in
"KUBA2009":1omt3cvn" said:
wrep in the comments and questions section about the use of architecture 7, but I guess there is no interest there.
Architecture or static forum All messages are read regardless of the difference and the content of the messages is evaluated. Good work
thanks for your interest . Since no information was given in the architectural part, I had to write it here. and the answer came, thanks.
hi, i searched the forum but still couldn't find a clear answer. Is there any harm in making a pile+flat in the raft foundation design? There is a difference of 20 tons of iron between the pleated+flat design and the flat designs on top and bottom. When designing with pleats, does the program check whether there is a need for reinforcement in areas that do not have reinforcement at the bottom (the areas where the pillar is broken)?
"jumboss":3uyh9ffi" said:
hello, I searched the forum but still couldn't find a clear answer. Is there any harm in making the pile+flat in the raft basic design? There is 20 tons of iron difference between the pile+flat design and the flat one on top of the other. When you design with pillars, does the program check whether there is a need for reinforcement in areas where there is no reinforcement at the bottom (the areas where the pillar is broken) or not?
Hi, the reinforcement type top+bottom reinforcement should be selected in the beamless raft foundation design. When the reinforcement type is selected as Flat+Pleat, negative moment in the support area and positive moment value in the span is checked. However, positive or negative moment can occur in any region of the foundation. Moreover, in the flat+pile option, the reinforcement design is made only according to the moments where the calculation axis passes. The moment values in other parts of the foundation not taken into account. Good work
"oya":25n9jevl" said:
Can we see the axles in the cassette beam expansions?
Hello, In cassette and rib flooring, the teeth expansions are based on the flooring names, the axles are not shown as you asked. You wrote a message to the forum about this subject; your request It was recorded at that time. Good work...
hi guys, i had a question, we draw the beamless slab like a raft slab in idecad7 and solve it with a semi-rigid diaphragm, how should we determine the load coming to the corridor part in this slab that we just created in places like the corridor where different live loads should be taken, thanks for the answers in advance.
Hello there; You don't have to define your floors as one piece. You can enter tiles with different loadings piece by piece using the tile edge command. Best regards.
Hello there; I need 1/100 scale for basic application, column application and mold plans. However, I cannot use the drawing interface efficiently at 1/100 scale. Although I doubled the font size, some texts may remain small. Is there a more practical way to set this up? Or what route would you suggest I follow?
Hello there; In my project, the basement curtain carries the reinforcements from the top. The lower ends also seem to be empty. why might it have happened?
