Levent Özpak
Active Member
Hello, In the program, continuous foundations are solved according to the theory of beams resting on elastic ground. In this solution, the foundation stresses are found according to soil bearing coefficient*displacement. Therefore, an increase in the foundation stresses can be observed when the bearing coefficient increases. It is at the discretion of the engineer to select which of the options in the stress control in the Foundation Settings. Recommendations for data entry; *Linear slab load is defined on cassette slab. Linear and point slab loads are for slab floors. In cassette and ribbed floors, such loads can be added to G or Q. **one. I think it would be more appropriate to give the same name to the split panel parts between the columns S11-S06, S06-S01 and S04S05 in the basement. Good work
