"HakanŞahin":1cqv92x7" said:
				"nahroyo":1cqv92x7" said:
			IN THE PROJECT I'M WORKING ON I HAVE CONTINUOUSLY DESIGNED FUNDAMENTALLY FUNDAMENTALS, AFTER I MADE ANALYZES AFTER THE MASTER CYCLE AND THE UPPER REINFORCEMENT IS NOT VISIBLE IS THIS A NORMAL SITUATION OR IS THIS A DESIGN Error?
 If you add the project, we will examine it...
 my project is normally b+z+4 floors, but I left b+z to reduce the size[/quote ] Examine the joint points of the panels P17-P15-P13-P12. The joint points of the continuous foundations connected to these elements do not coincide with the joint points of the panels whose names I have written. Similarly, the same situation exists for the right-hand elements. You can examine the attached project; The joint points of the continuous foundations are arranged to coincide with each other depending on the need for the foundations.In addition, we recommend that you enter the panels that continue to the upper floor and that are not in panel size (P17 and P12 etc.) as column objects.
