"legend":25xcasey" said:
when institutions are asked for both repair and defense, please repeat 7.22 for the projects in 7.022. I have to install or install 8.50 for the project in 8.5. When the control of the projects in 7.xx or 8.5x comes, do we need to install the old versions again. Or how to control the incoming projects in 7.xx with 8.61 installed in the institution. PC with 8.61 installed Are we also installing the lower versions of 8v separately. How can we do it?
You can install 7.22 separately from 8. For 8, uninstall the latest version of 8, then install the lowest version you want to install. All you have to do is take a copy of the exe and put it in the same folder. Then install higher version 8. For example. Uninstall 8.612i. Then install 8.504. Go to the program folder, make a copy of the ideCAD_Statik_8.exe file. Then install 8.61. After installation, you will have both the 8.61 ideCAD_Statik_8.exe file and the 8.504 exe whose name you have changed.
