When you say open with, you must also tick the option I have shown below."mrckby":26s5krin" said:Good afternoon, I upgraded from ideCAD 8.504 version to 8.62 version, even if it was drawn in the last version, when I try to open the analysis file, it tries to open it with 8.504 version and I get a warning that there is an updated version and you need to use a more up-to-date version. I can only open files with the 8.62 shortcut that comes to the desktop with installation and use the open file command from within the program. I did not have such a problem before, I started having such a problem in the static program after installing ideMimari version 8.504. . I have the same problem even though I choose the program to use with the open with command or from the file properties. I would appreciate if you could help. Good work
I applied what you said, but the result did not change."M. Berat Denli":1kazm6qi" said:When you say open with, you must also tick the option I have shown below."mrckby":1kazm6qi" said:Good afternoon, I upgraded from ideCAD 8.504 to 8.62 with an update Even if it is drawn in the latest version, when I try to open the analysis file, it tries to open it with version 8.504 and I get a warning that there is an updated version and you need to use a more recent version. I can only open files with the 8.62 shortcut that comes to the desktop with installation and use the open file command from within the program. I didn't have such a problem before, after installing ideArchitecture 8.504 version, I started to have such a problem in the static program. I have the same problem even though I choose the program to use with the open with command or from the file properties. I'll be happy if you can help me. Good work
If you want, call the Istanbul or Bursa office. You can help by connecting with Teamviewer. we will"mrckby":3l6zq43q" said:I applied what you said, but the result did not change."M. Berat Denli":3l6zq43q" said:When you say open together, you should also tick the option I showed below."mrckby":3l6zq43q" said:Good Day, I upgraded from ideCAD 8.504 to 8.62 with an update. I get a warning that you need to use it. I can only open files with the 8.62 shortcut that comes to the desktop with installation and use the open file command from within the program. I did not have such a problem before, I started having such a problem in the static program after installing ideMimari version 8.504. The file will be used with the open with command or from the properties. I have the same problem even though I chose the program. I would appreciate it if you could help. Good work
I also have this problem randomly. It is fixed when I exit the command, zoom in/out with the mouse wheel and enter the command again."miralay":13psj8qi" said:5-) Sometimes in commands that want to define two points, such as beam, line, curtain, etc., when you direct with the mouse and type the distance from the keyboard, the relevant object is It moves in the opposite direction of the mouse cursor. It doesn't matter if you write a positive or negative value. This problem is annoying sometimes.
I've reported this problem before. I didn't come across much in 8.62."MaFiAMaX":31c53g1k" said:This problem happens to me randomly. When I exit the command, zoom in/out with the mouse wheel and enter the command again, it gets fixed."miralay":31c53g1k" said:5-) Sometimes two point definitions such as beam line curtain etc. When you direct with the mouse and type the distance from the keyboard, the object moves in the opposite direction of the mouse cursor. It doesn't matter if you write a positive or negative value. This problem is annoying sometimes.
You can easily switch between all floors by clicking on the information line at the bottom of the screen. Maybe you know, but it seems very practical to me. Like the attached picture."miralay":31c53g1k" said:1-) Unnecessary clicks are made to go from the floor list to the top or bottom floor on the model screen. It will be very useful if the up and down floor buttons are added to the ribbon menu that allow direct access to one floor and one floor. If there is such a feature, I would be glad if you write it.![]()
Do you want the reinforcements of the horizontal beam to be extended, or is it the classical beam? Both seem past. I really don't understand. You wrote it from mobile. Project or screenshot Without it it will be difficult."AYDIN":15degk3y" said:Greetings - finally cantilever for beams whose cross section has changed, for example 25/50 deep beam post column post column 50/30 cantilever for horizontal beam transitions It does not give the minimum number of reinforcements for assembly in beams and flat reinforcements.In consoles, it is designed as reinforcement coming from the right column and coming from the left column, but when the continuation is deep beams, there are reinforcements coming from the columns 2 at the bottom and 2 at the top. It does not work to increase the number of assembly and flat reinforcement to 4. I hope I was able to explain. It would have been easier to upload a picture or a project, but I forgot to take a picture.
"zalman":6y0pzsz8" said:Hi Friends... IdeCad is not visible in the HKY Floor Parameters in the Latest Version. Was it taken to a different place? I couldn't find it...[ /quote] You will see in the attached picture.
Hello, Mr. Nedim' In addition to the information provided by "Structure Tree/Drawings", transitions between windows can be made easily."miralay":2000rq7o" said:First of all, I wish the Ide family a happy holiday in advance. I will have a few suggestions about the new version. 1-) From the floor list on the model screen, I wish you a happy holiday. or unnecessary clicks are made to go to the lower floor. It will be very useful if up and down floor buttons are added to the ribbon menu that allow direct access to an upper floor and a lower floor. If there is such a feature, I would be glad if you write it.![]()
These requests have been included in our notes for consideration."miralay":2000rq7o" said:2-) Beam expansions tab, where mold and column are in the application. Like all floors option would be nice. It would be nice to be able to choose a floor. 3-) Sometimes we model the stair tower as a masonry wall. It would be nice if there is an option to show the walls drawn with the wall command in the formwork plans. 4-) It would be good if the possibility of exporting the three-dimensional model as IFC would be added.
We would appreciate if you could attach a sample project file where this problem occurs."miralay":2000rq7o" said:5-) Sometimes, when two point definitions such as beam, line, curtain, etc. are required, when the mouse is directed and the distance is typed from the keyboard, the relevant object moves in the opposite direction of the mouse cursor. It doesn't matter if you write a positive or negative value. problem is sometimes annoying.
Hello, If you mean the situation in the picture when you mean that some of the commands turn into green balls, this image occurs when the commands do not fit on the screen. Resolution / screen size is not enough or the program working screen may be minimized.Subcommands can be opened and run by clicking the arrow sign under the command."AYDIN":664e8vjz" said:Greetings, I noticed a couple of problems in version 8.62 - I've customized the quick toolbar. Some of the commands I added turned into a green ball and changed their function. For example, the command for basic plan section drawing of the formwork. I had to add subtract again in every formwork plan.
"AYDIN":664e8vjz" said:- In the basement floor formwork plan, the drawing of the parking lot perimeter curtains protruding outside the building was not realized. He gave a drawing as if there were no elements between the columns. - Finally, in beams with varying cross-sections, for example, after 25/50 deep beams, post-column cantilever 50/30 horizontal beam transitions, it does not give the minimum number of reinforcements for cantilever beam assembly and flat reinforcements. In the consoles, it is designed as reinforcement coming from the left column from the right column, but when the continuation is deep beams, there are 2 reinforcements on the bottom and 2 on the columns coming from the columns. Increasing the number of assembly and flat reinforcement to 4 does not work. I hope I was able to explain. It would be easier to upload a picture or a project, but I forgot to take a picture.
I also have this problem. Sometimes it goes down when the cursor is up, and to the right when the cursor is on the left. There is no problem in other aspects."MaFiAMaX":3m31kj3j" said:This problem happens to me randomly. When I exit the command, zoom in/out with the mouse wheel and enter the command again, it gets fixed."miralay":3m31kj3j" said:5-) Sometimes two point definitions such as beam line curtain etc. When the mouse is directed and the distance is typed from the keyboard, the relevant object moves in the opposite direction of the mouse cursor. It doesn't matter if you write a positive or negative value. This problem is annoying sometimes.
Hello , Can you provide more detailed information about the condition under which this problem occurred?If necessary, we can also provide remote access to your computer at the time of the problem."proisa":23yp4ygl" said:I also have this problem. Sometimes when the cursor is up, it goes down, when the cursor is on the left, it goes to the right. There is no problem in other directions."MaFiAMaX":23yp4ygl" said:I have this problem randomly It also happens. When I exit the command, zoom in/out with the mouse wheel and enter the command again, it gets fixed."miralay":23yp4ygl" said:5-) Sometimes In commands that want to define two points, such as beam, line, curtain, etc., when directing with the mouse and typing the distance from the keyboard, the relevant object moves in the opposite direction of the mouse cursor. It doesn't matter if you write a positive or negative value. This problem is sometimes annoying.
