"AYDIN":2zys210k" said:
			Greetings, I noticed a couple of problems in version 8.62. - I customized the quick toolbar. Some commands I added turn into a green ball and lose their function. For example, the mold foundation plan section drawing command. I had to add subtracts again in each pattern plan.
 Hello, I gave the answer to this subject in my previous message. If you are talking about a different problem, install the teamviewer program and contact us by voice.
			- In the Bodrum snow mold plan, the drawing of the parking lot perimeter curtains protruding outside the building was not realized. It gave a drawing as if there were no elements between the columns (these two items came up in the last update.)
 Can you attach the project file where the curtains are not drawn?
			- lastly, for beams whose cross-sections have changed, for example, 25/50 deep beam post-column cantilever 50/30 horizontal beam transitions, it does not give the min reinforcement number for cantilever beam assembly and flat reinforcement. In the consoles, it is designed as reinforcement coming from the left column from the right column, but when the continuation is deep beams, there are 2 reinforcements on the bottom and 2 on the columns coming from the columns. Increasing the number of assembly and flat reinforcement to 4 does not work. I hope I was able to explain. It would be easier to upload a picture or project, but I forgot to take a picture. I may add at the beginning of the week. Good work. Pictures about the subject I mentioned before are attached
 I couldn't understand the problem from the picture you added. It is the reinforcement from the beam in the continuity of the assembly and flat reinforcement of the cantilever beam. If the assembly and flat reinforcement of the K52 beam is changed according to the beam names in the picture you added, the existing reinforcement area in the K51 cantilever beam will also change. If you have a different situation, if you attach the project file or provide remote access to your computer with the teamviewer program, we can examine the problem in more detail. Good work
