YasinTezel
Member
Re: Opinions about the use of ideCAD Reinforced Concrete 8 questions
			Hello, Drawing additional reinforcements twice is due to the difference in the slab calculation axis directions. To solve the problem, you can enter the reinforcement axes in the same direction. I think there is a slight difference in angles in the picture below. If you draw the calculation axes at the same angle using the parallel reference command, it will not be a problem. . Good work."siromar":j3bw284f" said:Generally, in the junction of two slabs on different axis, the support reinforcements are placed 2 times (both continuing and not continuing on the opposite slab) good studies
                     German
 German  French
 French  Spanish
 Spanish  Portuguese
 Portuguese  Italian
 Italian  Arabic
 Arabic  Russian
 Russian  Japanese
 Japanese  Turkish
 Turkish
	 I have sent the example about the curtain now. Good work.
