Download ideCAD Structural v10.93
Re: ideCAD Static IDS v10.09 Released *New*(02.05.2019)*Y The diameters of the reinforcements in the picture will be different, naturally the reinforcement sprout length will be variable.
"saridurmus":2uk4blb4" said:
The diameters of the reinforcements in the picture are different, naturally the reinforcement sprout length will be variable.[ /quote] Mr. Muhammed shared the sprout image to show that the dimensions of the curtain head and body reinforcement overlap.I also reported this problem in the previous version.
Re: ideCAD Static IDS v10.09 Published *New*(02.05.2019)*Y Thanks for the explanation, Mr. Omer. Frankly, I was surprised how you made that explanation, Mr. Ömer:) anyway, thank you for informing me.
Also, basic apl. The sprout details given in the plan and the sprouts given in the column/wall vertical details do not overlap.
I'm adding an image for what I mean by this expression. I hope it can be understood more easily... My expectation from the program is to match the details in the column length expansions with the shoots given in the basic application plan in terms of application practice.
Re: ideCAD Static IDS v10.09 Released *New*(02.05.2019)*Y hello, in a simple project I made for experimental purposes (high ductility level was selected), the moment capacity of my top floor curtains is as shown in the appendix. Why are the values showing zero? Thanks in advance to those who will help.
Re: ideCAD Static IDS v10.09 Released *New*(02.05.2019)*Y Hello; Since the situation that I have quoted from the regulation below occurs in these curtains, the design value mentioned in Figure 7.12 is used instead of Ve given in equation 7.16, and this situation is clearly stated in the report. Quote; The value obtained by increasing the shear force calculated from the earthquake according to Chapter 4 with loads by a multiple of 1.2D (gapless shear walls) or 1.4D (link beam shears), Eq. If it is less than Ve calculated by (7.16), this shear force will be used instead of Ve. Equation (7.16) also has shear force values along the Hw/3 region as described in Section 7.6.6.3. For walls satisfying the Hw/lw>2 condition, the shear force value found from Equation 7.16 in Section 7.6.6.3 along the Hw/3 region is compared with the shear force values calculated from magnifying the vertical loads and earthquake effects by 1.2D (or 1.4D), and this is The smaller of the shear forces is used as Ve. In this equation, Mp shows the moment capacity of the curtain and Md shows the moment value from load combinations. The Ve' value you see in the report is the shear force found with Equation 7.16, the Ve(limit value) value is the shear force obtained by increasing the earthquake loads by 1.2D, and the Ve value is the shear force used in the design. Apart from the increase used in 7.6.6.3 for the shear force values in the region above the Hw/3 region, the shear force value in the graph given in Figure 7.12 is also included in the comparison. Apart from the shear forces found with the increased seismic forces, the graphic values in Figure 7.12(b) are also taken into account. In this case, if the value greater than the cutting force and increased cutting force values found in the graph is the design cutting force, you marked it in the report, and the design cutting force is written as the value found on the graph. Since values such as Md and Mp are not used in the calculation of the shear force found in the graph in Figure 7.12, information describing the method of calculation is shown in those columns in the report. Best regards...
"Mirza":3hraapl8" said:
Hi, the program does not detect the changes I made to the blocks in the 1. Annotations folder. I tried in both ProgramData folders but no result. I can't create title with the blocks I created.. There was no problem in V7.. 2. "Final Selection" does not work in 2D drawing editing windows, it cannot find the last selected object after heavy processing... it detects the object too late..(one of the most frequently used commands in drawings) 3. While the object selection window is from right to left in V7, it does this from left to right in V10... is there a possibility to change it? 4. While exporting 2D drawings, route objects in the drawings cannot be scaled... (if the unit is meters, scaling does not occur) 5. Nodes selected with the "Move Node" command would become prominent. not understood in versions, V10... 6. "Settings from Object import / export" command can be expanded... a menu can be added to specify which settings are to be imported or not... need: import/export layer name as well as color and pattern... (Autocad---match feature or Sap2000---Copy Assigns/Paste Assigns) 7. The program works slowly even though there are not many elements in the drawings... good work, regards...
These minor problems caught my attention as well. I would be very happy if you consider it in the update.
Re: ideCAD Static IDS v10.09 Released *New*(02.05.2019)*Y Hello.. I posted this project on another page, but I'm posting it here because it's urgency.. We couldn't save the account somehow . Due to the decrease in ground values, we converted it to a rafter raft. In addition, we analyzed the system according to the fully rigid diaphragm, now when we convert it to semi-rigid; -We couldn't prevent the excess shear force on the curtains. -Some of the continuous bases also got errors. We would be very happy if you could help us. Good luck with. The latest version is in the link below.
Re: ideCAD Static IDS v10.09 Released *New*(02.05.2019)*Y Hello, will the distribution reinforcement drawing be made on single foundations? It's not a problem to draw, but it takes time to add it to the footage. Although we do not use it very often, we may have to use single foundations in solid ground and large-span structures such as factories.
"MaFiAMaX":2djpjanw" said:
Hi, Will the distribution reinforcement be drawn on single foundations? It also takes time to add to the quantity.Although we do not use it very often, we may have to use solid ground and single foundations in large-span structures such as factories.
Hello, Mr. Erhan, I take your request into our notes.
Re: ideCAD Static IDS v10.09 Released *New*(02.05.2019)*Y Hello, While trying to analyze my model, the program closes without any errors. Interested?
DATA CONTROL, KIRIS CROSS-SECTION CONDITIONS 2007 EARTHQUAKE YÖ. WHEN THE DATA CONTROLS, BEARING SECTION CONDITIONS 2007 EARTHQUAKE REGULATION ARTICLE(3.4.1.1 WRITTEN. IT IS STATED AS 7.4.1.1 IN THE NEW REGULATION. GOOD WORKS
Re: BEAM CROSS-SECTION CONDITIONS WHEN DATA CHECKED 2007 EARTHQUAKE
"mustafaureyen":2lr5ezlp" said:
HELLO EASY EVERYONE WHEN DATA CHECKED, BEAM SECTION CONDITIONS 2007 EARTHQUAKE REGULATION 1.1. STATED AS 7.4.1.1 IN THE NEW REGULATION GOOD WORK
Hello, Your statement has been taken into our notes. Thank you.
"emreyaykin":zu23sw3v" said:
Hi, While trying to analyze my model, the program closes without any errors. Are you?
The project is modeled in the scaffolding project file. For your analysis, open an empty project with a black template and create the floors from the floor general settings. Then copy each solid in this project to the template project you opened using the copy/paste from file commands.
Re: ideCAD Static IDS v10.09 Released *New*(02.05.2019)*Y Thank you very much. I noticed it after I sent it to you and I completed the analysis as you said without any problems. Good work.
İdeCAD Reinforced Concrete (GENERAL, HELP) Good Day Hello ; My first serious project with the ideCAD reinforced concrete module, there are a few issues I would like to ask; 1- ) I am checking the project analysis results, only the AS reinforcement problem remained in the analysis part, I can't get over it somehow. Although I come to the reinforcement parameters and choose the diameter and range I want to use for foundation and flooring, the last time I want to exit, the slab reinforcement diameter is not selected ... etc Later on, the diameters of the reinforcement I set change, I have to enter and correct each time 2- ) What is the small-angle object error in geometry control? 3- ) 4 Insufficient flooring in the basement or faulty floor axis warning. I said choose the object, I couldn't find it 4- ) The project consists of 4 basement + z + 13 normal floors. Its period is 1.7 seconds I think it is normal for the current regulation 5- ) I could not connect the columns in some axles of the project due to architectural reasons, the company does not want beams to be passed through the rooms. We couldn't evaluate other flooring systems because the building was in height limitation, I had to use 14 cm in the halls and 12 cm in the other rooms because we were stuck within the floor height limits of the zoning regulations. If there are deficiencies in the project, could you please edit the small things you see. Project Link:
Thank you. Best regards.
Re: İdeCAD Reinforced Concrete (GENERAL, HELP) Hello;
1- ) I am checking the project analysis results, only the AS reinforcement problem remained in the analysis section, and I can't get over it somehow, although I came to the reinforcement parameters and selected the diameter and range I want to use for the foundation and slab, the slab reinforcement diameter was not selected the last time I wanted to exit ... etc. gives warnings. Later, the diameters of the reinforcement I set change, I have to enter and correct each time
If you increase the additional reinforcements, there is no problem in the slabs where you get the As reinforcement error in your model. In the program, you can lock the main rebars with rebar fixing, but you need to check the additional rebars after each analysis.
2- ) What is small angle object error in geometry control?
The "small angle object" message in the geometry control is a "warning" message. If the objects in your model have that angle in the project, you don't need to take the warning into account.
3- ) 4 Insufficient floor in the basement or wrong floor axis warning, I say choose the object, I couldn't find it
If you make a selection with the mouse from right to left in the area I marked with red on each floor in your model, you will see that there are independent elements such as:3 selected in the command line. . Make selections and delete these elements on each floor.
5- ) In the project, I could not connect the columns in some axes. Due to architectural reasons, the company does not want beams to be passed through the rooms. We couldn't evaluate other flooring systems because the building was in height limitation, I had to use 14 cm in the halls and 12 cm in the other rooms because we were stuck within the floor height limits of the zoning regulations. TBDY 2018 may ask you to make a solution according to article 4.3.4.4. Since you marked the beamed slab in the Analysis settings wizard as the slab type, you are not doing this solution now. Select cork flooring in the Analysis settings wizard to make a solution according to TBDY 2018 article 4.3.4.4. Since there is no article about mixed flooring systems in the regulation, you can ask this situation to the control authority.
Re: ideCAD Static IDS v10.09 Released *New*(02.05.2019)*Y Berat Bey ; I edited the parts you said, now there is no problem. I also modeled the frame , foundations and floors with other programs and I will design the reinforcement accordingly . Good work. Best regards...
Re: ideCAD Static IDS v10.09 Released *New*(02.05.2019)*Y When I start Risky structure analysis in the demo version, the program closes. I can run it on 1 of the 3 computers I use. In the other 2, the program closes after the analysis window is opened and the process starts. Is there a known cause and solution? The operating system on the failing computers is Windows 7 Enterprise x64 and Windows 10 Pro x64.
"S.Onur":a7g8i1xs" said:
When I start Risky structure analysis in demo version, the program closes. I can run it in 1 of them. In the other 2, the program closes after the analysis window opens and the process starts. I wonder if there is a known cause and solution? The operating systems on the computers that fail are Windows 7 Enterprise x64 and Windows 10 Pro x64.
If you install Teamviewer and call us remotely we try to identify the problem by looking at your computer with access.
Re: ideCAD Static IDS v10.09 Released *New*(02.05.2019)*Y Hello; Would it be right to do a push over analysis for a renovation project where we will make changes in floor heights and column size for a project with the old regulation? If so, how can we get the report of the push over analysis results? I wish you good work.
