batuhann28522
Re: ideCAD Static IDS v10.05 Released (14.03.2019) Good afternoon. When will the update come to get risky building analysis and performance report? I wonder if some programs have been updated and the files are waiting?
Good day, answer is"batuhann28522":zf9z5p3b" said:Good afternoon, when will the update come to get risky building analysis and performance report? case files are waiting?
Thank you. We can't report, right, on 10.06. There is an urban transformation file, a performance report is requested, I wonder if it's risky building Is it possible to get a risky building report, not performance, after the analysis?"MaFiAMaX":221e0uyr" said:Good afternoon, reply:You do not have permission to view link Log in or register now.
"2m project":3tlxvx9j" said:Hello, It is a risky building analysis and report required for urban transformation. This is V10.06 If you upload your project here or send an e-mail to the ide structure, you will be returned.
Hello, I have sent the link of ideCAD Static v10.06 to your e-mail where you can analyze risky buildings and get reports."batuhann28522":1sch7m9o" said:I would appreciate it if you could send reports so that the values and equipment that will enter into urban transformation remain the same. My e-mail address is @hotmail.com][email protected]
"emreyaykin":388a1s9b" said:Hi, good work; When I click on the grid and border settings, the program crashes and closes. The file is attached.[/ quote] Hi, This occurs when trying to enter the grid and border settings from the right-click menu. The problem has been fixed in the next update. You can use the General Settings, Grid Borders tab to change the grid and border settings. Good work
Good days. I had a risky building analysis, but it should not be considered as a risky building. When we do a normal analysis, I get such a result even though the beams and columns do not approve, am I doing something wrong that the building will enter into urban transformation?"HakanŞahin":2akylcyq" said:Hello, I have sent the link of ideCAD Statik v10.06 to your e-mail where you can analyze risky buildings and get reports."batuhann28522":2akylcyq" said:Reports on values that will enter into urban transformation, so that the equipment remains the same I would be glad if you could send it. My e-mail address: [email protected]
"batuhann28522":atgm6rti" said:"HakanŞahin":atgm6rti" said:Hello, ideCAD Static v10, where you can analyze risky buildings and get reports I sent the link of .06 to your e-mail. quote] A structure that does not save in normal analysis may not come out as a risky structure."batuhann28522":atgm6rti" said:I would appreciate it if you could send reports so that the values that will enter the urban transformation remain the same. My e-mail address: [email protected]
Mr. Yasin, 3. I would like to give a brief information about which results I want to see in the article. Column capacity diagrams should be added to the reports. Color scala gra for raft foundation should be included as a full page attachment. Regarding the intermediate processes, the transition between the raw combination raw values found by the program as a result of static and dynamic analysis and the design values used in the reinforced concrete design should be as transparent and traceable as possible in the reports. In addition, Idecad has incorporated some of the regulations into combinations in V10. These sections should be given in more detail in the reports. As you know, IFC has become the Industry general standard. That's why I want it added. In addition, Tekla Model Dump export option should be opened for reinforced concrete users. As it is, we are exporting via demo. Finally, the body diameter in the beam settings tab of the reinforced concrete settings is standard 12. Even if the user changes it manually, the drawings are still 12. I'm asking for this to be fixed."YasinTezel":2z6z3u3n" said:A few notes I would like to add; 3-) In the transition from raw results to design results, the program performs most TBDY and TSE500 operations. doing it in the background. I would like these steps to be given in a little more detail in the reports. At least, it can be written in the relevant parts of the reports as an explanation of which calculation steps the relevant loads are passed through. We are working on this issue. Could you elaborate on which values you would like to see in your controls? We can export the 3D Model in DWG , PDF , Tekla , OBJ formats. I take your IFC export request in our notes. Could you please let me know which software you want to use IFC for exporting? Thank you for your interest.
