yusuf15hira17
Re: ideCAD Static IDS v10.03 Released Hello Mr. İsmail; As you suggested, when my finite element width was 25 cm, I increased it to 1 meter. I was doing the modal parameters as you said, I didn't do anything there. Although I made a semi-rigid solution, the analysis made in 23 minutes was reduced to 4 minutes. Thank you for your help. Would I have done something wrong if my finite element widths remained 1 meter? What disadvantages could there be? Best regards.
"Ismail Hakki Feeds":11l1k3to" said:While determining the column wall dimensions of your building; Uncheck the semi-rigid option in the upper left corner of the screen. Uncheck the Uz Rx Ry Rz freedoms in the modal parameters. Make the floor and curtain finite element spacing 1m. After deciding on the design and handling the deficiencies, when performing the final analysis, if the structure does not require semi-rigid, do not solve semi-rigid. Respose spectrum analysis for vertical earthquakes. If there is no need, remove Uz from modal parameters Do not mark Rx and Ry in modal parameters"yusuf15hira17":11l1k3to" said:Hi; With the new program, my analyzes are completed in a time ranging from 10 minutes to 40 minutes. I had ram upgrades, ssd upgrades etc. as I thought it was caused by my computer. Although I increased the speed of my computer considerably, there was no change in the analysis time. Is there a way to shorten this analysis time?
