Did you know that? (Hint)
You can turn the midpoint mode active or inactive"[/u][/i][/b] by pressing the "F5 key on the keyboard. While any object command is selected and midpoint mode is active; When you move the mouse cursor over the objects, it automatically finds its midpoint and when you click the left button, the cursor jumps to the middle of the object.
"Copy to File" command can save the objects (data) you selected as ideCAD block(.blk), [u You can import the block files you saved with the ]"Paste from File"[/u] command into your other ide projects.
You can tilt your tiles with the "Bevel objects" command from the tiling toolbar. To give slope to your flooring; - Click the Bevel objects icon from the tiling toolbar. - Select the tile you want to bevel and click the right mouse button. - Select/not select the objects around the tile from the dialog. - Draw your reference line to determine the direction of the slope. - Adjust your settings in the Tilt options dialog.
"status bar", which is a band at the bottom of the screen, writes what needs to be done at each step after entering a command.
If the "Space-bar" key is pressed while placing the jamb on the window and door, the symmetry of the jamb is taken.
With the "Block" command, you can turn your two-dimensional drawings into blocks and sub-blocks and provide a faster working environment. To block 2D objects; - Click the Change/Block line in the classic menu, and the Drawings/Change/Block icon in the ribbon menu. - Select the 2D objects to block. - Press the right mouse button. - The 2D objects you select will become blocks. The drawing before using the block command: The drawing after using the block command:
When the ”buttons in the upper right corner of the perspective screen, the middle” button is pressed, it shows only the floor being studied or all floors.
"Draw/Objects/Site Edge/Site Edge" or "Entrance/Location/Location in the ribbon menu You can define two different areas by dividing an existing space with the edge ". For this;
  • 1. Click the Draw/Objects/Site Edge/Site Edge line in the classic menu, click the Entrance/Location/Site Edge icon in the ribbon menu. 2. In the area where you want to define two different areas, draw your border as you want it to be divided. 3. When you draw your border, the program divides the area into two and your location becomes defined only in one area. 4. To define a zone for your other area, use the Draw/Objects/Location/Location line in the classic menu or the Mahal icon from the toolbar, and Enter/Location/Location[/] in the ribbon menu. b] Click the icon. 5. Define your location by clicking on your second field.
To bring the last step of your stairs to the same level as the landing; you should tick "Last step at upper level" option in ladder settings.
With "Export/Save screenshot" option, you can save the image of your plan screen as a picture. 1. Click the Project/Export/Save Screenshot line in the classic menu, and the ideCAD icon/Export/Save Screenshot icon in the ribbon menu. 2. The Save Image dialog will open. After the desired settings are made, click the OK button. 3. The Save File dialog opens. Specify in which format you will save in the File types section below. 4. Type a name in the File name line. Click the OK button and your plan screen will be saved as a picture.
"Corner window" to draw; walls are drawn with the "Circular wall" command, and the number of curved wall points is given as "1" in the wall forward settings. If you mark the tilted door/window option in the door/window settings; windows take the shape of your wall and settle in, if the flat door/window option is checked, they will be placed by chamfering your corner wall.
You can use the command "Advanced object duplicate" to make multiple copies on a curve or lines. Here are the steps you need to follow:
  • 1. First, define the pattern line by drawing line, circle, arc, curve (open or closed bezier, nurbs) objects. 2. Click the Change/Advanced Object Duplicate line in the classic menu, and the Enter/Change/Advanced Object Duplicate icon in the ribbon menu. 3. Select the object or objects you want to duplicate in the drawing area by clicking with the left mouse button, then clicking the right mouse button. 5. Give base point by clicking with the left mouse button. (The base point can be any point, usually it is given as one of the object node points. Objects are reproduced based on this point. The base points are located on the pattern line.) 6. Left-clicking a second point in the drawing area base direction[ /b]. 7. Select the object or objects (line, circle, arc, etc.) that make up the pattern line by clicking with the left mouse button. 8. After the selection is finished, click the right mouse button. The Advanced Duplicate Object dialog will appear. 9. Make the necessary settings in this dialog and click the OK button. Objects will be reproduced according to the given parameters and the selected line.
You can open spaces in spaces with the "space space" command. The area of the space automatically falls from the area of the spaces and is reflected to the square meters of the space simultaneously.
You can switch between ribbon menu titles by "moving the middle mouse button back and forth" while on the ribbon menu. In the ribbon menu, the middle key navigates back to the right. In the ribbon menu, the middle key navigates forward and left.
With the "Auto-scale ribbon icons for DPI" feature, you can automatically scale the icons in the ribbon interface according to the resolution when working on UHD high resolution displays.
  • - Click Settings/General Settings line in the classic menu, Settings/Project Settings/General Settings icon in the ribbon menu. - In the dialog that opens, in the General Settings tab, tick the line Automatically scale ribbon icons for DPI. - When you restart the program, your icons will be scaled automatically according to the resolution.
If you want to use the classic menu instead of the ribbon menu, you can uncheck the "Use the ribbon menu" option from the General Settings dialog. - Click the Settings/Project Settings/General Settings icon from the menu. - In the dialog that opens, in the General Settings tab, uncheck the Use Ribbon menu line. - When you close the program and open it, the classic menu will become active. Similarly, the ribbon menu will become active when you select the option and close and open the program.
