Hello My Suggestions
Exiting the console from the column as you did is not a suitable solution, you should change it"civilization":13v49nm3" said:I understand that there is no problem with the columns and beams in the 4 corners of the building, is it true.
It is more convenient to solve it together to take the horizontal forces by connecting the elevator curtain to the building, both are different in a separate solution. Since it will move, sufficient space (dilatation) should be put in between. Unver ÖZCAN"civilization":13v49nm3" said:Finally, an elevator will be placed in the gallery space and there will be curtains on both sides. But this curtain has no connection with the building, should it be more logical to solve it separately or together with the building.
