-In the project you added, there are relative translation problems and column beam joint shear safety problems in Ver 10.14 demo version. Joint shear safety problems in Ver 10.14 were not given in the project error detection list Summary report Column beam joint shear safety report and Column reinforced concrete When the dialog is examined, it can be seen that there are Joint interrupt security problems. -Additional work done in Ver 10.17 and 10.20 versions released after Ver 10.14 are given in the link below."AUGURD":29xflysu" said:Hi.. When I did the same project in the demo version, I did a problem-free project, but I bought the original version and there are always problems ...
Suggestion and project attached.In your last project, there will be no problem if you make raft reinforcement Q18/10 and this reinforcement Q20/10 Also, in your project, there is a column arrangement on top of each other, there is no beam between S10-P16 on the ceiling of the 1st floor, Ünver ÖZCAN"AUGURD":3mbywmhb" said:Hello, I think I've reached the end of the project, there are 8 errors left and unfortunately I can't solve the last problems even though I tried everything, please can you help me, I reviewed item 9, you can make changes on the project, thank you in advanceYou do not have permission to view link Log in or register now.
Hello, -In the project you added There is a lack of reinforcement in the cantilever slab entered with the index S. The project is single storey and the foundation system is continuous foundation -D07 and the adjacent slab D01's reinforcement axis no. 2 are common Arrange additional reinforcements as fi8/15. AS(-) problem will be solved. - Version 8 is not compatible with TBDY2018."mehdiduman":1p1x8kvs" said:greetings. I made a cafe project with a semi-basement raft-based cafe, but I can't fix the column deficiency. It also doesn't show the raft drawings
Can you download the untitledproje.ide85 project file you added and check it again? as follows."mehdiduman":u7tonfds" said:I modeled the foundations in the form of rafts in the idecad surname I added, I did not use foundations all the time.
I added"mehdiduman":2meahylh" said:hello. I made a semi-basement raft-based cafe project, but I can't fix the column deficiency. It also doesn't show the raft drawings
-In the cafe.ide85 project you added; -There is a stapling problem in the columns on the basement floor. The solution to the problem can be increased raft thickness, higher-strength concrete can be used, if the punching problem is in the outer columns and there are no ampathes, ampathes can be made... -Foundation and reinforcements are drawn when the foundation application plan is taken both on the basement floor and on the ground floor. Project notes; -one. the D02 slab in the basement is incorrectly identified and the meshes are not formed correctly. Redefine the flooring. -one. There are no perimeter curtains in the basement. It would be appropriate not to accept the floor as rigid. You can review the item 35 of the frequently asked questions and answers document about B1 weak floor irregularity."mehdiduman":2meahylh" said:with some changes and the same situationYou do not have permission to view link Log in or register now.
"Levent Özpak":38liybjp" said:"ltfoncl":38liybjp" said:I GET CONTINUOUS WARNINGS TO INCREASE THE SYSTEM RIGIBILITY. THE SYSTEM CANNOT RECOVER IT, I'D LOVE TO HELP FILE :You do not have permission to view link Log in or register now.You do not have permission to view link Log in or register now.
Unver, could you please take a look at my post?"unver":1aburki5" said:HelloThe proposal project is attached. If you make the raft reinforcement Q18/10 and this reinforcement Q20/10 in your last project, there will be no problem. Also in your project, there is a column arrangement on top of each other, there is no beam between S10-P16 on the ceiling of the 1st floor, Ünver ÖZCAN"AUGURD":1aburki5" said:Hello, I've reached the end of the project, there are 8 errors left and unfortunately I can't solve the last problems even though I tried everything, please can you help me, I checked item 9, you can make changes on the project . Thank you in advanceYou do not have permission to view link Log in or register now.
