Hello, I could not solve the relative storey drift problem, I did c30, I enlarged the section, I added a curtain, could you take a look, I added a link
[ /quote] Hello, Because your project has a very weak ground such as Ground class ZE, the relative floor drift values are high. You can check the link below for the relative floor drift problem and possible solutions.
- TBDY 2018 Article 7.5 with regard to Joint Interrupt Security problem(B) and Frequently asked questions and answers document item 9.
Column S05 in the project, which gives a Join break safety warning K25-K26 beams connected in the Y direction have no common intersection area. Consider the option of not resolving these two beams continuously. (In the "Rebars" tab of the properties of the K25 beam, the line "Continuously accept beam at the right end" can be unchecked) -For raft foundation punching problems and possible solutions, you can check the link below.
Good studies
