Ismail Hakki Besler
Administrator
Re: New Earthquake Code 2018
As the earthquake design class (DTS) increases in number, it represents the region with less earthquake hazard. That is, the most dangerous region is the one with DTS=1. Indeed, in the column of DTS: 1 and 2 in Table 4.4, it is higher. It was allowed to calculate the building with the Equivalent Earthquake Load method. İsmail Bey took part in the committee, he explains it to us. I think there is a typo or we are misinterpreting it."2nmuhendislik":grwmitio" said:New earthquake regulation Table 4.4 In the application of the Equivalent earthquake load method, as the earthquake hazard class decreases, the allowed building heights have also decreased, with an interpretation of strangeness Is there any?
Hello Mr. Ismail, Isn't it wrong to write BYS=> 4 in the first column of the first row in Table 4.4 and BYS=>5 in the second column?"Ismail Hakki Besler":p1dsey2b" said:Doesn't allow for higher structures. It allows structures with Hn <= 42 m in both groups. This height for irregular structures It is limited to 28 m.
The statement written in the regulation is not wrong. It is a normal situation. The equivalent earthquake load method gives far-reaching results as the building height increases and if there are irregularities in the structure. Therefore, the restrictions for this calculation method are given depending on the building height and the building irregularity. But instead of BYS, Hn If he did, there would be no confusion."MaFiAMaX":h6zwhnl6" said:Hello Mr. Ismail, Is it not wrong to write BYS=> 4 in the first column of the first row in Table 4.4 and BYS=>5 in the second column? ?
Hello Mr. Ömer, What me and 2nmuhendislik are comparing is not the BYS limit for regular and non-regular buildings.The question we asked is why is it written BYS=>4 in the first row and first column of Table 4.4? The first line was BYS=>5 in the second column"siromar":2tec8ri8" said:BYS=> 4 ---- BYS 4-5-6-7-8 Buildings lower than 42m (torsion and soft Buildings without floor irregularities) BYS=>5 ----- BYS 5-6-7-8 Buildings lower than 28m (torsion and soft story irregularity can also be found) In short, if there is no torsion and soft story irregularity, the equivalent earthquake load is on a higher floor. It's a perfectly normal situation.
I made a comparison of irregularity because it was called the Second Column. You made a comparison in the line. Ismail Bey's answer was also explanatory."MaFiAMaX":7uu3vbvl" said:Hi Mr. Ismail, Isn't it wrong to write BYS=> 4 in the first column of the first row in Table 4.4 and BYS=>5 in the second column? ?
comes into force."S.Bozdağ":1qjl8giu" said:Is there any progress on the release of İdecad version 9.xx? We are planning to publish the 9.xx version before the 2018 Regulation of Sefa Bozdağ İnş.Eng
You will be able to upgrade from ideCAD Static 7 to ideCAD Static IDS v10."hydrkrmn":17yvkjzi" said:HOW WILL IDECAD 7 BE COMPLIED WITH THIS NEW REGULATION.
"Mirza":38mzv2l0" said:Hello friends; The communiqué on "Design Supervision and Control", which is mandatory for structures within the scope of Article 1.3 of Turkey building earthquake code 2018, has been published. I would appreciate it if you would share your views and suggestions about the content and implementation practice of this communique. Good work, regards..You do not have permission to view link Log in or register now.[ /quote] Thank you. Let's check it out.
