Report the commands you have difficulty using in the ribbon menu
Re: Report the commands you have difficulty using in the ribbon menu if you look at my picture, there is no change tab
Re: Report the commands you have difficulty using in the Ribbon menu
Hello, Modify tab is active in the layer window.To be able to use the Change Object Layer command while in the drawing window You can add to the "Quick Input Toolbar" in the upper left corner for this. To do this, right click on the 1. ribbon menu. Click on "Customize Quick Toolbar". 2. Select Modify from the opened screen and find the "Change Object Layer" command. Click the Add button 3. Then click ok and the command "change object layer" will appear in the upper left corner. Good work
Re: Report the commands you have difficulty using in the Ribbon menu Hello, If all the axes are defined in your project and you still can't get the axis drawings, can you send your project? Good work.
Re: Report the commands you have difficulty using in the Ribbon menu Hello excalibur_24
"excalibur_24":1z6quuxm" said:
Mrb I can't find the accessory settings
If the accessory selection you are looking for is from the front page
masmay wrote: EASY IDE 8.61 CHANGING SEARCH I CAN'T FIND THE PERCENTAGE "REINFORCEMENT SELECTION" ICON. CAN YOU HELP ME? I CAN'T HAVE ANALYSIS ACCORDING TO THE REINFORCEMENT DIAMETER I WANT, SO... Under the Analysis and Design tab Ünver ÖZCAN
Re: Report the commands you have difficulty using in the ribbon menu Hello, my problem is that the quick entry toolbar in the ribbon menu is very small. It hurts my eyes so much I need to enlarge them. Is there a solution?
Re: Report the commands you have difficulty using in the Ribbon menu Hello, the features we have the most difficulty with; -Dimension command, section view command must be in the input tab. Or the commands in the Ribbon menu should be individually editable.
Re: Report the commands you have difficulty using in the Ribbon menu hello, has the mold/basic section command in the drawing in version 7 been removed in 8.61? The section option in the drawing does not appear to be active
"a_clout06":f6n6qgms" said:
hello, has the formwork/foundation section command in the drawing in version 7 been removed in 8.61?
Hello Your question has been answered in the following topic
"yunussacikk":5jamg7fa" said:
I couldn't find the turn beam to curtain command
Hello, you can use the Right-click menu or you can use the "Convert" section in the "Change" tab .
Re: Report the commands you have difficulty using in the ribbon menu using the ribbon menu; it's really DIFFICULT as a user who has been using the old menu for years. so every time I open a project, I first close the ribbon menu from the general settings, save the project, close and open it again. Seems to be no problem so far. but why do I have to do the same operation over and over in the same project file? It's really annoying to do the same thing all the time in the same project that I opened at different times, "closing the ribbon menu." I'll be pleased if you pay attention. good work.
"tolgatilav":2g730bff" said:
Using the ribbon menu is really HARD as a user who has been using the old menu for years, so every time I open a project, first close the ribbon menu from the general settings and close it. , I save the project, close it and open it again. It seems like there is no problem until here. But why do I have to do the same action over and over in the same project file. It's really annoying to do the same thing over and over in the same project that I opened at different times, "closing the ribbon menu". I would appreciate it if you're interested. Good work.
Hi, when the "Ribbon menu" option is canceled in the General Settings dialog, it will not be active again unless the line is marked again and the registry is reset. Cancel the ribbon menu option and close the program. When you run it again, the ribbon menu If you install the team viewer program from the link below and call us, you can examine the status on your computer by remote access. we can.
Good work
"isik_insaat":10au5mi2" said:
zoom commands are not available in the ribbon menu
Hello, your question was answered on page 2 of this topic. //www.idecadsupport.com/forum/viewtopic.php?f=5&t=5371&start=20#p23818]viewtopic.php?f=5&t=5371&start=20#p23818[/url]
Re: Report the commands you have difficulty using in the Ribbon menu I can bring the primitive objects with the command, they are not in the menus. Can it be added under the objects tab?
"sultanfatih":2orbtabk" said:
I can bring the primitive objects with the command, they are not in the menus. Can they be added under the objects tab
You can see the primitive objects in the Drawings tab.
Re: Report the commands you have difficulty using in the ribbon menu thanks, I guess I missed it. Also, is there a circle slab edge option for a raft or a continuous foundation, and a circle continuous foundation drawing is possible or can it be added
Ribbon menu Hello, I don't want to use the ribbon menu, so I close it from the settings, I restart the program, I use it without any problems, then when I restart the computer, the ribbon menu comes back every day. I'm tired of closing the ribbon menu and restarting the program every day. I'm waiting for your help. thanks
