Apocalpyse
Re: Ribon menu I do exactly that, when the computer restarts, it opens again with the ribbon menu
Do you get an error when you close the program?. I want to run ideCAD Static with Admin rights Try it. Maybe the last settings are not saved when you close the program. If the problem persists, we can contact Teamviewer and look at your computer."Apocalpyse":2xnvx1mo" said:I do it just like that, when the computer restarts, it opens again with the ribbon menu
I felt this deficiency too, but when I added the commands I use frequently to the quick toolbar, it was very practical. It can be accessed on every screen. Maybe on high resolution screens the buttons may seem small."NYILMAZ":ew0z9d4l" said:I expect some commands to be more easily accessible Commands needed in almost every environment: Layer related commands Line command Route command Dimension Area These types of commands are frequently used (or I use) commands during work. They are necessary not only on the drawing screen, but also on the data entry screen. In this case, it is not practical to change the menu. Also, it would be better if the same commands remained fixed in changing menus. Example: [ u]Change command group[/u] it appears elsewhere on the screen in the reinforced concrete menu, in another place in the steel menu, in another place in the drawing menu.This is the change command group[/ b] breaks his habit.
Hello, The endpoint edit command has not been removed, just the way it works has changed. The way it works is as follows: 1) Select the element, 2 ) Move the mouse to the tip of the element you want to edit and click . You can move it to the ground. You can also mark more than one element in the intersection and edit the ends of all of them at the same time. Also the command works in 3D. Please try and let us know your opinion again. Good work"AYDIN":86wvjlkt" said:Another issue, please give us back the "endpoint edit command" in old versions. Move node command without any problems it works, but when I want to capture the nodal point of any element at a node where there is more than one element at a node point, it sometimes catches the node of the element and sometimes it does not.For example, when I want to take the end of a beam that goes in the middle of the curtain and put it on the column at the beginning of the curtain, sometimes it is easy, sometimes it does not We were able to do what we wanted with the 'edit endpoint' command with zero problems. Please return the command to us via iPhone using Tapatalk
Install Version 8.62. Pattern / Basic in Tools You can use the create plan section command."cenkmiri":3graf3bl" said:I could not find the pattern plan section in the pattern plan. Good work.
In Ribbon Menu -->Reinforced Concrete tab-- You can select Risky Building Analysis from the opened window by clicking on the ->Analysis-Design Button tab.After analysis report tab will also be opened."damlatpz":asb0v15r" said:I could not find the Risky Building Analysis options and reports in the toolbar, I would appreciate it if you could help me
