Report the commands you have difficulty using in the ribbon menu
Re: Report the commands you have difficulty using in the ribbon menu Hello Mr. Nedim, I gained a lot of speed by adding the commands I use most frequently to the quick toolbar, I recommend it. Now when I switch to the classic menu, I am stunned. Since I still use the classic menu in CAD software, I did not expect that I would get used to the ribbon menu in ideCAD.
Re: Report the commands you have difficulty using in the Ribbon menu Erhan Bey, I have added some commands to the quick toolbar, I am adding them. However, I am writing what I think is related to the general use of the program as a recommendation. It didn't even work, I went to the classic menu and made new right and left toolbars and added to them. When I use V7, I see that my hands are wandering around my feet. :) But still one expects some commands to be in some places. Greetings.
Re: Report the commands you have difficulty using in the ribbon menu Other menus disappear while on the 2D drawing screen. That's okay, that's understandable. But some commands are getting farther away. For example: to reach the pen thickness command, you will first switch to a 3D screen. Then to the settings menu, then to the pen thickness command. Then you will be back to the 2D screen from there. Therefore, the settings menu must also be active in 2D. Commands that cannot be used here may be inactive.
Re: Report the commands you have difficulty using in the Ribbon menu I NEED TO CONTINUOUSLY TURN OFF THE RIBBON MENU AND CONTINUOUSLY RE-START IF IT IS NOT CONTINUOUSLY CLOSED, I WOULD LIKE TO HELP..
"anchor52":3ldp7z1x" said:
I NEED TO CONTINUOUSLY TURN OFF THE RIBBON MENU AND CONTINUOUSLY RE-START IF IT IS CONTINUOUSLY CLOSED, IT IS NOT CONTINUOUSLY CLOSED. occurs when the version is run. You need to cancel the Ribbon menu again from the General Settings. Good work
