Report the commands you have difficulty using in the ribbon menu
fathhh
Re: ideCAD Static 8.61 *New Version* Hello. Good luck with the update version. I can't find the contour lines option, which we clarify by rotating the axis boundaries, is it a different situation?
"fathhh":2401539m" said:
Hello, take it easy.. Very nice update version. I wonder if this is the case?
There has been no answer for how many days, contour lines, I think the contour lines have turned to calculate, and the contour copy has been added, but the contour does not work with the calculation, am I not able to get it to work?
"dagcitorunu":nz18bhys" said:
"fathhh":nz18bhys" said:
Hello, take it easy.. A very nice update version, thank you. I can't find the option of contour lines, which we clarify by rotating the axis boundaries, is there a different situation?
There has been no answer for how many days, contour lines, I think it has turned to calculate contour, and copy contour has been added, but the contour does not work with calculation, or am I unable to work it out? ?
Hello, you can use the "Calculate Contour" and "Draw Contour" commands just below the Axis command.
ideCAD Static 8.61 I could not find Rebar Selection in Ribbon menu CAN YOU HELP ME? I CAN'T HAVE THE ANALYSIS DONE ACCORDING TO THE REINFORCEMENT DIAMETER I WANT, VS.
Re: ideCAD Static 8.61 Cannot find Reinforcement Selection in Ribbon menu
"masmay":by135q2m" said:
EASY, I CANNOT FIND " REINFORCEMENT SELECTION" ICON IN THE CHANGEABLE INTERFACE IN IDE 8.61. BEAM VS. I CAN'T ANALYSIS ACCORDING TO THE REINFORCEMENT DIAMETER I WANT, SO...
Re: ideCAD Static 8.61 Can't find Reinforcement Selection in Ribbon menu THANK YOU, HAKAN. I WAS CLICKING ON THE TEXT NOT THE LOGO, THE WIRE REINFORCEMENT WAS COMING. THANK YOU AGAIN
new version architecture In version 8.61, the toolbars cannot be set to the old classic style, I find everything I'm looking for very difficult
Re: new version Hello, disable the ribbon menu option from the general settings tab and close the program and open it again. Good work.
Re: new version
"kutluinsaat":2q5px7hm" said:
architect in version 8.61 toolbars cannot be set to old classical style I find it very difficult to find everything
What are you looking for and where did you look to find it?
Re: Report the commands you have difficulty using in the ribbon menu If "Show menu with right click" is not active; Since the last command with right click is activated, it is necessary to do ctrl + right click.
Re: Report the commands you have difficulty using in the Ribbon menu There was quick change under the Change command. Is this on the menu too?
Re: Report the commands you have difficulty using in the Ribbon menu I could not find the parameters, I would be glad if you could help.
"evrenor59":2j9tlei4" said:
I could not find the parameters, I would appreciate your help.
Click the arrow sign under the Reinforced Concrete icon that appears in the attachment.
Re: Report the commands you have difficulty using in the Ribbon menu How can I access the change object layer command in the following menu? By the way, I will make a general suggestion... even if we don't offer it as default when an innovation is made, it would be better if we entered the settings and set it, for example, I think you added a ribbon menu, it's very nice, you are progressing in a modern programming concept, but put an option like "open the ribbon menu" in the settings, let the ribbon do it. If you want the classic to continue, maybe you did what I said, but I think if the ribbon didn't come by default... As we are used to using 8.5, there are some moments when I say should I not use 8.61 because I cannot get used to it. I even like using AutoCad with class. If you remember, Microsoft brought the metro interface with Windows 8, then gave up on this radical decision. The essence of the word; Your updates are right in place, it would be better if we make the changes for the application optional. I'm in your wing. Thanks in advance dear friends
"mkrts88":1ysdk08h" said:
how can I access the change object layer command in the following menu?
Under the Change tab, in the Layers group... You can see it in the attached picture.
by the way, I have a general suggestion... even if we don't offer it by default when an innovation is made, it would be better if we went into the settings and set it, for example, you added a ribbon menu, it's very nice, you are progressing in a modern programming concept, but "ribbon Put options like "open the menu" in the settings. You can access the General Settings from the upper right corner of the program.
