Hello, A detail like you sent is automatic The required part of the formwork plan can be transferred to the staircase drawings by copy-paste method.2D Drawing can be prepared with editing commands."batuhann28522":ceacvee6" said:hello. When I get the staircase drawing from idecad, the beams on the side do not appear, so they do not appear, how can I connect them or how can I show them. I gave an example of the project and what I want to say. I would appreciate it if you could help
thanks for your reply. How do I do it with 2D drawing, where is the edit 2d drawing command?"YasinTezel":1vmyzots" said:Hello, A detail as you sent is not drawn automatically. The required part of the formwork plan can be transferred to the staircase drawings by copy-paste method. It can be prepared with the 2D Drawing editing commands.
"YasinTezel":1b3jukg1" said:After the pattern plan is created, select the part you want to copy on the stair detail sheet and copy it with CTRL + C. Switch to the stair detail sheet and paste it with CTRL + V. 2D drawing editing tools mean line, offset, trim and move commands like.
Thank you very much for your answers. I will only ask one more thing. What are the quantities that we can get from idecad without the progress payment program and how? I can look at the iron used, from the drawing, but can I access the concrete and formwork quantities. Because I do not have a licensed progress payment program. Can I at least access the concrete and formwork quantities or is there a quantity program that you know of that I can use without a license?"YasinTezel":3qfd64ev" said:The program does not provide these details automatically. You have to make the drawings of stair shoots etc.
Hello, in your project Arrange the stair abutments according to the solution conditions independent of the structure, and select the Full rigid diaphragm and Earthquake Load Method "Apply the horizontal forces calculated by mode combination to the rigid diaphragm" option. The problem of insufficient number of modes will be corrected. Additional information for data entry in the program; - Solution of the stair abutments together with the structure In case it is arranged according to the conditions of the semi-rigid diaphragm, it is appropriate to analyze according to the assumption of semi-rigid diaphragm. - The idle edges of the ladder should not be marked as fixed supports, but should be left empty. -In the staircase with a landing, the lower edge of the upper arm of the ladder is not connected to the stair landing. -Linear floor loads in the solution according to the assumption of full rigid diaphragm hollow block and cassette on the floor is not taken into account. -The transverse teeth defined in ribbed floors transfer loads to the beams to which they are attached. If it is desired to be constructive (not load bearing), ribs should be defined without creating transverse teeth. Transverse teeth should then be added to the drawings using 2D possibilities. - A single console floor without continuity cannot be solved. (Example 1st floor D16) -40 cm. shorter ribs are not resolved. (Example 1st floor D02 In this case, you can model the floor as a slab floor.) Good work"furkizbey":3enss1om" said:Hi, When I analyze the program, I get the error "The number of mods included in the dynamic calculation is insufficient". Even though the number of mods is exaggerated, I even made 100, it gave the same error. How can I fix it. Good work
The message "No beam under normal force" is not an error to be fixed, it is a condition. Program TDY 3.4.1.2 It controls this situation with reference to it.See TDY 3.4.1.2."tayfuner":31f2b09q" said:How to fix the error There is no beam under normal force in the project. Where could I have made a mistake
