"illaga":1iqxejch" said:
How can we read the effect of the column header in the un-beamed slab in the attached table? I entered the column head as table height=15 cm, floor space=3 cm, slab thickness=26 cm, column head elevation=-26 cm. Is this correct?
According to the table you added, line 1 is Slab+screed, total height is d= 15+26-3 =38 cm, row 2 is for slab only, d=26-3=23 cm. Since the column header will be under the slab, the elevation value you have given is correct... Although the program gives a negative result because it is a table, there is no need to consider the verification made for the slab.
