Levent Özpak
Active Member
Hello, There does not appear to be a problem with data entry in the project.
Hello, The situation you stated is due to the fact that the stair exit column is not connected to the intermediate landing and the upper rigid floor number is taken differently for both directions in the Analysis settings. When creating a staircase, create the contour of the intermediate landing in parts as in the example. I think it would be more appropriate to take the upper rigid floor number as -2 for both directions due to the BAP03 angled curtain."proisa":3e6sdhxj" said:Hello In the project I added, when I received the Elective Report, although there was no B2 irregularity in the irregularities section, in the same report, there was B2 irregularity in the selection reasons section of the R Coefficient. Therefore, although there is no both A1 and B2 irregularities, the lower limit in dynamic analysis value takes Beta of 0.9. What is the reason? Thank you
"NYILMAZ":2nh49j2l" said:I know that all of the information I requested below is somehow available in the program. Nevertheless: Performance analysis reports, reinforcement or general analysis report results Can it be in elective report format as it is? Or performance analysis reports; - building layouts - building general information - beam loads - slab loads can be added? Also performance analysis in the preliminary information; - information level coefficient (I know it is written in the table, but...) - earthquake level used - calculated performance level - expected performance level can be added? /quote]"unver":2nh49j2l" said:Supporting Mr. NYILMAZ's proposal. 1- Like "Earthquake regulation general report" (icon); Can we get the results from the screen with the "reinforcement regulation general report"(icon)? 2-"Selective reports"(icon) already; In "Static report settings" there is a section "Boost reports" . If the options currently printed in the retrofit report are added here, the retrofit reports can be printed, along with all the information we print in the optional reports. Take it easy"ryildiz":2nh49j2l" said:Does the program control alpha s in systems with normal pitched ductility level? According to TDY 2.5.3.1, alpha s >=0.75. ( However, as less than 0.75 although the program does not notify about changing the ductility level)"yagmurcankocak":2nh49j2l" said:I wish you a good day, I searched the forum but could not find it, so I opened a new thread. I would like to ask, for beams with high ductility level (same condition for beams with low ductility level) according to TDY 2007, there is a restriction in article 3.4.1 (a) that the minimum beam width will be 250mm. Although I selected the ductility level as high in my model, I could not see any warning in the program when I used 200mm wide beams. Have I overlooked something? Good work, Yağmur Can KOÇAK]"yagmurcankocak":2nh49j2l" said:Good afternoon, "The smallest dimension of rectangular columns is 250 mm and the cross-sectional area is less than 250 mm for the cross-section of columns in the column cross-section control (TDY 3.3.1.1). It shall not be less than 75000 mm². Despite the clear statement that "the diameter of circular columns will be at least 300 mm", when I define a circular column with a diameter of 300 mm in the program, I get a "column with low cross section" warning. I think cross-sectional area control is applied in circular columns as well. I wanted to share. Good work, Yağmur Can KOÇAK"siromar":2nh49j2l" said:I noticed something wrong in the column shear safety section of the report, take it easy, good work
The regulation may have been published yet, it will be published soon.. To the last text we obtained from the Ministry of Environment and Urbanization (Rules to be used in Risky Building Detection_23_01_2013.pdf)"proisa":22iilb8v" said:Where can I find the published regulation on identifying risky buildings. Interesting but I could not find the technical regulation on the internet.
During the analysis, the critical solid program asks us."proisa":22iilb8v" said:How is the risky floor determined?
The elevation of the column does not affect the punching calculation... We don't need to give the elevation as much as the height, but in the section, it will look like whatever you give the column elevation."proisa":25b8eicn" said:When we define the column header due to stapling on the raft foundation, do we need to give the column in the basement the same height as the column header?
Hello, the changes made in the Layer Settings/ Drawing Details tab only work on the active floor. When the apply to all floors option is checked in the General Settings, the current settings are applied to all floors. Then the dialog It is normal that that line does not appear marked when entered. Good work"NYILMAZ":vr6x0vtp" said:I tick the command apply general settings/settings to all windows in the program. I move to another floor, there is no sign when I look there. I come to the same floor I marked again, the old one So, for example, I want to scan the beams on all floors (drawing details/beam scan), but only the current floor changes, I have to do each floor separately Where is the problem?
Hello, Since the polygon column is a bar element, there is no beam or beam in between. Floor edge cannot be entered.You can enter the polygon column with panel objects and model it as a shell.Good work"izmirlimuhendis":1tzo6zh6" said:I want to connect the two ends of the U side of the S20 column (polygon U column) with a beam, but I can't define a beam. Can you help me.
