windtalker
Hello, in which cases the redistribution principle specified in TS500 can be used. Does it create a more negative situation in terms of safety as plastic hinge formation is allowed? Thanks for your answers.
Hello, Performing Redistribution Linear Analysis can be applied in any situation that fulfills the conditions given in TS 500 Article 6.3.8 Equation 6.14 in the program - Apply TS500 Redistribution clause-[ If the /b] line is marked, it is checked whether the conditions given in Equation 6.14 are met in the beam supports. If the conditions are met, the support moments and, accordingly, the span moments are automatically calculated. There is a plastic hinge formation in the load-bearing elements from the moment the moment carrying capacity is reached. plastic hinge formation (moment carrying capacity) is slightly reduced. The moment carrying capacity at the outlet is also increased. More detailed information on the subject can be obtained in the chapter 2.10 Moment and Force Harmony (Pages 126,127,128,129,130) of Mr. Uğur Ersoy-Güney Özcebe Reinforced Concrete. Good work"windtalker":2dysoxu9" said:Hi, in which situations can the redistribution principle specified in TS500 be used. Does it create a more negative situation in terms of safety as plastic hinge formation is allowed. Thanks for your answers.
"windtalker":2ofcv1k6" said:Hello, in which situations can the redistribution principle specified in TS500 be used. Does it create a more negative situation in terms of safety as plastic hinge formation is allowed. Thanks for your answers.
If you do not have the book, the attached document will help you. In order to obtain the book; Uğur Ersoy-Güney Özcebe, Reinforced concrete enhanced printing, Basic Principles and calculation according to TDY, 2001 Evrim Publishing House..."Levent Özpak" :2ofcv1k6" said:Mr. Uğur Ersoy-Güney Özcebe's Reinforced Concrete book, 2.10 Moment and Force Harmony (Pages 126,127,128,129,130) more detailed information on the subject can be obtained.
You solved the system according to the TDY 1975 regulation (Equivalent load method). The report is blank because there is no column beam shear safety control in the TDY 1975 regulation. If you solve it according to 2007, you can see the report. In short, the situation is not related to the change in slab thickness ... Solve with either the Mode Combination method or the Response Spectrum analysis option in the analysis settings."1. For the message "BODRUM Objects Not Connected to Rigid Diaphragm", the situation is related to column S19. Indeed, the column is not connected to any rigid diaphragm."windtalker":2omgylor" said:Hi there, after analyzing the attached structure, the column-beam junction safety report I received was "1. There is a phrase like "BODRUM Objects Not Connected to Rigid Diaphragm". And it does not indicate the shear safety of any column-beam junction. Although it gave hundreds of errors in my first solution, after I changed the floor thickness on the left side of the structure to eliminate the errors, the problem I mentioned above appeared in the column-beam junction safety report. what is the reason :?:
Shouldn't you have left the ductility level selection "normal"? ."windtalker":3t38v4zs" said:You are right, but the joint safety report appears empty in the solutions I made with dynamic methods.
Jeans -There is a problem in the height relationship. If you follow the steps below in the general settings of the floor, the height and elevation values can be adjusted step by step. 1. Make the height of the ground floor 1000 cm, for example. 2. Make the elevation of the ground floor 70 cm. 3. Make the height of the ground floor 290 cm. 4. Then make the heights of the 1st and 2nd basements 290 cm, respectively. 5. The height of the 3rd basement will automatically be 290 cm. 6. Click OK."windtalker":3dseq142" said:The elevation values I want to enter in the apartment project in the attached file are also available in the attached screenshot. Even though I enter these values, the floor settings are restored. What do you think could be the problem. Thanks in advance for your answer.
Hello, Acceleration Spectrum Multiplier In the earthquake code article 7.8.1, in the evaluation of existing buildings, it is specified as 0.5 times the acceleration spectrum ordinate for buildings with 50% probability of exceedance in 50 years, and 1.5 times for buildings with 2%. For new buildings, this value should be taken as 1. Spectrum multiplier is in Performance Analysis Options as of version 7. It is determined automatically according to the probability of exceeding the earthquake selected for the Targeted Performance Level."windtalker":1f3ov2y9" said:Hi, What is the spectrum multiplier found on the behavior spectrum function screen under the basic soil tab in the analysis settings? How many should be taken for which types of structures? Is it related to the building importance factor?
