Fixes reported in the forum and fixed in version 7.015:
"tavekkul":1z1xcp7u" said:
can you make ide wrep 7 for the output so we don't have to save it as an old version.
"sonerizgi" :1z1xcp7u" said:
b+z+5 floors I entered a project in the report vis vik values y direction 0
"my clerk":1z1xcp7u" said:
I encountered a problem in the last version such as writing on the plans and details transferred to 2 dimensions or while moving the lines, the mouse wants to move in the direction of 90 degrees or 45 degrees (usually), I cannot carry it comfortably and freely as in the old versions. works..
---->The mouse wants to jump to certain angles due to the new polar tracking feature. In such cases, you can turn off polar tracking from Settings->general settings. You can use the apat simultaneously by pressing the F3 key.
"sonerizgi":1z1xcp7u" said:
Hakan Bey, in previous versions, when it was asked what is the right button, the explanations were coming out. They were very useful, maybe a friend is saying them
of course, I'm telling you
I need a windows update, I couldn't figure it out.. . a few friends have stated the same problem by the way... good work
----> What is this help has been removed because it is not compatible with 64 bit program structure. Instead, it has been edited so that help will come when pressing the F1 key in the dialogs. For version 7 Work has also been done on new and unhelpful dialogs and commands.
"umutozalit":1z1xcp7u" said:
while drawing objects (continuous basic) space key is changing very slowly when entering eccentricity
----> Misalignment was changing but not refreshing problem There was, it was fixed.
"Murat":1z1xcp7u" said:
ideCAD Statik version 7.014, after editing and locking the rib reinforcements, when we perform the analysis, the reinforcement is deleted in the locked ribs and a reinforcement error occurs in the locked ribs. We need to make corrections after the analysis. Hope to fix it in new versions.
[quote ="ahmetozates":1z1xcp7u"]greetings, in our 12-storey project, the program always uses 14 gauge iron for the columns, I wonder if I'm doing something wrong with the project settings, the 16 gauge iron is not selected at all, whereas the 16 on the table is selected at 16 on the table, I would appreciate it if you could help, I would appreciate the project at the link. [/quote]
"Levent Özpak":1z1xcp7u" said:
"mehmetdindas":1z1xcp7u" said:
When we open a project produced in İdematik in İdestatic; 1-Does the program transfer the walls that we do not define as beams to the floor as a linear load?
In idecad architecture, the wall loads entered on the floor are taken into account. However, there is currently a problem with the calculation of the wall load value defined on the slab. We added the situation to our detection list.
"dabanlio":1z1xcp7u" said:
Hi, sometimes the stirrups (transverse reinforcements) are not written on the opened reinforcement in the curtain details and vertical details of the curtains given in the application plans, and their lengths are not given either. I could not understand the reason for this. ?
"katibimin":1z1xcp7u" said:
in the column application plans, version 7 does not write the distances of the column edges to the axes partially, why was this written in the 5 versions now. Or can we not make an existing adjustment in the column settings, please, we will be glad if we are enlightened. regards...
----> Column joint point may not be placed at axis intersections. In addition; Even if the column nodal point is not at the axis intersection, if there are two axes that intersect on the column, those axes are taken into consideration.
"NYILMAZ":1z1xcp7u" said:
The attached zip file contains a block file. I selected all the objects on one floor in a project. I said copy to the file and made a block. Then when I tried to paste from the file, the program broke. I wanted to call it into a new project, the same situation again It happened. I tried the same thing for another floor and the same thing happens. I don't know which object is caused by incorrect blocking. Maybe it can be tried one by one. All columns or all beams or I don't know, other elements can be blocked one by one, but I haven't examined them. ]
By the way, all beams appear as unsupported beams in geometry control. I couldn't make any sense. This could possibly be the reason, but I don't know why this happened. However, I did not go to any fix so that the problem could be found.
"KUBA2009":1z1xcp7u" said:
Hi, I opened the same topic 15 days ago, but I did not receive a reply. Did I have a problem????? As you can see in the picture I added, the material section does not appear in the settings dialog when creating a door or window.[ /quote]
"saridurmus":1z1xcp7u" said:
After adding to a project drawn in ide6, the program closed itself while increasing the number of floors. Even though I used the ctrl+shift key, when I tried to open the project, it still didn't open.
---->The condition that caused this situation has been resolved.
"bha":1z1xcp7u" said:
good day, the program crashes when I try to take the footage in the attached file of the ide build. I uninstalled and reinstalled the program, I encountered the same error, but I do not encounter this problem with other files, how can I solve this problem
----> This project-specific situation has been prevented from occurring.
