Levent Özpak
Active Member
Re: Opinions about using ideCAD Reinforced Concrete 8 questions
Hello, you can access it from the section under the Reinforced Concrete/Axle command or from the menu that opens when you right-click on an empty area in the Plan Window."batuhann28522":2bsmjngd" said:good day.I cannot adjust my contour lines in ide8. Change-object edit- there is no contour, only contour calculation exists and I cannot do it from where. Can you help me? I can't assign my axles.
