Re: ideCAD Static IDS v10.03 Released
Yasin, first of all, thank you for your interest. When I selected the ductility level as mixed and removed the 4/5R option, there was a decrease in reinforcement in the s1(30/60) and s2(30/60) columns, but it calculates 24 22 reinforcements even though I increased their dimensions. By the way, we get an error that the ductility level Mdev calculation should be chosen as 4/5r and limited in the report, as you said in the report, that is, we chose mixed in hollow systems according to the regulation, how can we fix this? The final version is in the link, thanks"YasinTezel":2sz6rfkd" said:Hello, you have set the Ductility level to Limited. In rib systems, you have to solve with the mixed ductility level. Attached Prof.Dr. You can review Nuray Aydınoğlu's explanation. An update on this will come in the TBDY 2018 Wizard. Limited ductility level cannot be selected in rib systems. Since you take R 4 and reduce it with 4/5R in your project, it decreases to R = 3.2. Therefore, column and curtain reinforcements have increased and you are experiencing cutting problems. 4.3.4.6. You have to satisfy the condition Mdev >= 0.75 Mo. When you provide this ratio and choose the ductility level as Karma, you can get R as 5. 4.3.2.4. Clause conditions will be optional in the next version. In order to provide ductility conditions, my suggestion is to reduce the curtain ratio by turning the perimeter curtains into columns. Try to place 2 curtains in the middle area in the X and Y directions. In all beams, stirrups are tightened from the face of the column, only the beams are not tightened when they are stuck in the columns. There is no problem here, as the regulation states that the compaction will be made from the column face. If you're talking about columns. With TBDY 2018, the column length reinforcements are made in the middle of the column. Since the column wrapping area is made both in the middle region and at the lower and upper ends, the entire column is tightened. The wrap zone length at the lower and upper ends was changed to 1.5 bmax. (TBDY was as much as b max in 2007.)"fathhh":2sz6rfkd" said:Hello. According to TBDY2018, we tried to make a hollow block project static for the first time. However, there were too many reinforcement assignments in the columns, and we saw that there was no stirrup tightening in the joint areas. we got k error on the curtains. I wonder if we made a missing or incorrect information entry in the data entry, such as R coefficient, pursanta value in the columns, etc. We would appreciate it if you could help us to examine and see our shortcomings. Thank you in advance. The link is below.You do not have permission to view link Log in or register now.İHA_GÜNER.ide10.html
UAV_GUNER.ide10.html
