Mert Kaymaz
Hello Dear Colleagues, Min 30/70 columns are accepted by the Municipality, and the beam reinforcements are min. 14 iron and are accepted as both assembly and flat reinforcement. The system gives an error when I set the beam settings to throw the 14-gauge irons in the analysis settings, but when I make the first analysis and then fix the iron reinforcements manually, it does not give an error on the beam. How can you suggest a solution, my beam dimensions are 25/60
