'Projects solved in the ideCAD environment are based on the economic calculation principle.' Then ideCAD is doing analysis and calculations. The 3 purposes of engineering are - Safety - Economy and Aesthetics. Real engineering is to bring the structure to the optimum point in terms of safety and economy. In other words, whether the design is economical or not is in the hands of the engineer. I could not figure out its relevance to ideCAD. Otherwise, I could not use this expression for ideCAD It means staying on the unsafe side."illaga":3356dp15" said:What comes to my mind right now, in addition to the section and reinforcement tolerance in the Analysis settings, it would be beneficial for the engineer to add a negative tolerance in order to stay in the safe direction, because the economic calculation principle is based on the projects solved in the idecad environment. Reinforcement may be required when the project designed as laminate is later converted to tile coating. Or when a simple steel construction is desired to be built on the roof, reinforcement may be required in the existing structure. In such cases, it may be convenient for engineers who want to stay on the safer side for the required section/reinforcements.
"saridurmus":h40vm7p8" said:Hi, Mr. Nedim, I think you are tired of waiting today and you think you need innovation.
I definitely don't want such a change, or rather a big change. Look at the Autocad app... it just changed the EXPLODE icon, which cracked the core until many people found it. And even he left the change optional. Wouldn't it be more important to ask for what you find missing in the output (calculation and/or drawing) rather than visuals"saridurmus":pnowqbvc" said:need to shrug once in a while. As texting says, it is necessary to consider the visual aspect as well
"saridurmus":2ztadyw8" said:need to shrug once in a while.texting should also consider the visual aspect[ /quote] I wasn't going to laugh at all in the evening, Mr. Yellow is yellow.
