Re: What do you need to do to print out in cad environment ?????? Hello If you can install ideCAD in the office where you will print out. The ideCAD WREP program is a print-only program that works unlocked. It can be accessed from the Windows Start menu ideCAD / ideCAD Architecture / Tools menu. You can print directly from the ideCAD project you are working on. or if you want to submit your project as DWG. DWG drawing is created with Project Export / DWG Export. It is created in the file containing the pen thicknesses with the CTB extension with the same name. Using these two files can be output in other CAD software.
