URGENT sentinel key not found (h007) error
farukborak
we formatted the pc a short time ago, the file of ide6 was completely deleted, I installed ide 7 with help from the forum and inserted the key, it worked for two days without any problems, but now the key is inserted, the light is on, but it still gives the error in the title, this is the warning it gives when I don't insert the key, I think is there a solution for this? I need to train three-dimensional drawing urgently, I am adding your help. ii works thanks.
"farukborak":32rv7kdr" said:
recently we formatted the pc, ide6's file was completely deleted, with help from the forum, I installed ide 7 and inserted the key. warning, I think there is a solution for this, I need to prepare a three-dimensional drawing in the morning, I urgently add your help. ii works thanks.
Hello, Your lock is probably broken. Contact us from Bursa office, connect to your computer with remote access and look at the problem. If the lock is broken, the cost We change the lock in return. For this you need to send the lock to us. But first let's look at the problem on your computer... 09.00 - 18.00, tel: 224 220 67 17
I installed the idecad 7 static program for the first time as a demo. But I am getting sentinel key warning without opening? What to do?
