Re: transferring the layout blocks to cad???? If you export/dwg after creating the layout, it will be transferred. Dwg and ctb files are created. When you give these two files to the plotter office, your output is printed with pen thickness. The layout should only be used for output (not for working in autocad), if you create and export the layout, all the drawings in autocad come in the standard layer.
