The reason why the mold plans do not appear properly in the report is because of the distant objects that I mentioned in the other message. In the last project you added, if you remove the half or missing teeth on your D6 and D13 floors on the ground floor by interfering with the tooth gaps or the initial tooth width, there is no problem with these floors. In addition, it would be appropriate to arrange your beams, which appear halfway in the plan formed on top of your main carrier beams in your other floors. In the other case, you have designed your D17, D14 and D1 floors as a single console. Surround these floors with beams, or design the rib beams to be continuous with the other floors.
