Render Questions
u_yet
Hello there. I would like to ask a few questions about rendering. I would be very happy if you answer. 1-) Can I render the floor plans so that the doors and windows are also visible? Since I'm looking over the wall right now, I see walls where there are door and window spaces 2-) When I render the floor plans, the stairs go inside the wall. However, if I can render at a certain level, for example, at +1.50, the upper part of the ladder will not be visible. 3-) Do I have a chance to assign materials to wall sections in floor plans? The wall sections remain white in the renders I'm currently taking. 4-) The border lines look slightly jagged even when rendering at "very high" setting. What can I do? 5-) Is Batch rendering possible? Thank you so much
The answer to your 1st and 2nd questions is available in the link I gave below.
If you take the elevation of the roof at the level that will cut the window and the door in the cut with roof command, windows and doors will also appear. 3-) When cutting with roof, whatever color you select in the Texture box in Roof trimming settings, that color will appear in the cut areas. If you choose auto texture, all cut elements get their own texture. 4-) I will not be able to comment on your problem with border lines without an example. I can help if you upload the screenshot of the problem, your render settings and the project here. 5-) Batch rendering is not possible.
The files you want are attached. The problem with the softness of the edge contours is evident in two of the renders (19-20) I have submitted. Good in the other. In addition, I would like to ask: The sky jpeg in the background is 3000 * 5000 pixels in size, but pixelation is seen in the blue areas. The picture size is small. What can I do?
Attached files are not uploaded, choose 'Use panoramic background image' for sky, say browse, you will need to select the target folder as Sky, after selecting the folder click ok, choose a sky and finish the process by saying ok
