Rename entities automatically
demir
hello, take it easy, it names the objects sequentially in the automatic name option, can you give the same name to an object with the same properties and the same dimensions, for example, to give the same name to the windows with 120/130 dimensions (LIKE P1)
Select objects with the same properties, use the select command on all floors. Enter the object edit command on the 3D screen, change its name. All of them will have the same name. The thing to note here is that if automatic naming is done again, the name will change.
