According to the earthquake regulations, the number of R floors should not be taken as 8 in curtain wall systems. There is an account regarding the selection of the R floor number in the İdecad report section. For example, if you take the alpha as 0.76, you can choose 4x0.76=3.04, and the R coefficient is 10-3.04=6.96. When you write this value, you will not get the error you mentioned. The maximum pursanaj error is taken due to the shear force in the beams. I know that you should either increase the dimensions of the beams mentioned or increase the diameters of the reinforcements inside. i hope it helps
