polygon column wall problem.
ozguer
I'm drawing a polygon column on the wall with a slanted axis, but for some reason I'm having errors in the combination.?? You can say that the column wall does not overlap.. but I paid attention to it too... I erased and redrawn it many times...
It says the file is too large. I deleted the floors. Only one layer remained. the room is around 3 mb.. he said it is too big... i compressed the project and saved it. can you tell me is there any other way to send this file???
"ozguer":3j6cuo71" said:
it says the file is too big. I deleted the floors. One floor remains. The room is around 3 MB.. it said it is too big... I saved the project by compressing. Can you tell me is there any other way to send this file???[ /quote] to sites like
or
you can download.
"ozguer":3ibtxmpg" said:
I draw a polygon column on a wall with a slanted axis, but for some reason I am having errors in the combination. You can say that the column does not overlap the wall.. but I paid great attention to that too... I erased and redrawn it many times... but didn't work???
There are two polygon columns on top of each other. Select and delete the top polygon column. The plaster transitions will be smoothed.
this will be the file. I also marked some places in the drawing with a revision cloud. I will be happy if you look. Also, the tile names are not visible in the mold area. the tile I imported into the cloud was defined incorrectly. I think it has something to do with the polygon column. Best regards
file. I also marked some places in the drawing with a revision cloud. I would appreciate it if you look. Also, the tile names are not visible in the formwork area. The tile I have included in the cloud is defined incorrectly. I think it has something to do with a polygon column. Regards
The column elevation in question is set to 270. By setting the column elevation to 0 and re-entering the slab, the problem disappears. I think the other thing you mentioned is a matter related to the wall combination. I couldn't study that subject because I don't have an architectural program, but it may be probably the same reason. Take it easy...
The column elevation in question is set to 270. Set the column level to 0 and re-enter the slab. The problem disappears. I think the other thing you mentioned is a matter of wall joint. I couldn't study that issue because I don't have an architectural program, but it's probably the same reason. take it easy...
thank you for your reply . but.. I can't see this information in the formwork plan even though I marked it so that slab names, column names and beam names would appear. Best regards
"ozguer":2qt79ofv" said:
.............. thank you for your reply . but.. I can't see this information in the formwork plan even though I marked it so that the slab names, column names and beam names will appear.. I would appreciate it if you could help me on this subject. Regards
There are drawing details in the layer settings. You can mark what you want to be drawn for each object in the drawing details.
In addition, for the lines in the corners of the column in the upper left corner, if you hold the end of the wall with the endpoint edit command and attach it to the inner points, not the upper left corner of the column, the problem disappears.
Hello, In addition to what Mr. Nedim wrote, I wrote the explanation about the problem in the flooring in the ozguer22.cde file. In the formwork plan, the beam is under the polygon column. When you grab the end and drop it on the corner of the column, the floor boundaries are defined correctly. Good work
