saridurmus
file cannot be downloaded
The biggest period in the building (1st mode) is determined as the Natural Vibration Period of the Building. The name of the direction is written in which direction the effective mass in this mode is. ux: x direction uy : y direction rz: torsion"gunner":gp86hk86" said:there is something else I would like to ask about the reports. In the building summary report, in the title of determining the earthquake load, in the line where the natural vibration period of the building is located, ux, uy, or rz are written in parentheses. T is determined according to uy instead of displacement in x direction ?
1) Open the Windows "Run" command. Type the following command from the ideCAD program folder. 2) " C:\Program Files\ideCAD\ideCAD Static 7\Drivers\install\haspdinst.exe" -r -fr -kp -purge -v 3) This command will delete all key drivers from the computer 4) Disable virus program or security program if any Leave it or unsafe "haspdinst.exe" 5) Restart the computer 6) Reinstall the lock driver by typing the following command 7) "C:\Program Files\ideCAD\ideCAD Static 7\Drivers\install\haspdinst.exe " -i -kp -v 8) Enable the virus program. 9) Restart the computer and run the program."baskutay":1vco1njd" said:when we install the new version, a warning appears that the lock system is old and the program does not work. I would appreciate your help
I think you made a data entry error. Your ground safety stress will be 19 t/m2, not 1.9. It cannot be 1.9."tedarmi":1loc4tvq" said:how can I fix the ground safety negative error in the raft foundation, friends...you can download and review the project below
Could you add your project?"illaga":jynkcof6" said:My foundation system is continuous foundation..After the analysis, Max. Soil stress values in the Reinforced Concrete/Continuous foundation dialog show zero except for a few foundations. What is the reason for showing zero.
"illaga":2nnya9yx" said:My foundation system is continuous foundation..After the analysis, Max. Soil stress values in Reinforced Concrete/Continuous foundation dialog show zero except for a few foundations. Continuous Foundation joint points may not be on the columns, the foundation part may remain under the column object, etc...
I think you are talking about a S08 polygon column here because its details are prepared according to the reinforcement plan in 120 scale. There are no anomalies.You can also edit the details of stirrups and crossties by using the Draw/Reinforcement/Stirrup-Stickers commands.If you want the middle part of the column to be equipped like a curtain, you can enter a panel object between two columns."tedarmi":1a3695k8" said:GIVES AN INTERESTING DRAWING THAT I DRAW THE COLUMN APPLICATION IN THE FOLLOWING PROJECT HOW CAN I CORRECT IT CAN YOU SEE FRIENDS
Floor edge is drawn under the K19-k17 beams in the basement. Therefore, it gives more than one rigid diaphragm warning. Due to the remaining slab edges, the raft slab boundaries are formed incorrectly.The continuity of rib calculation beams is not defined correctly."tedarmi":2gsyvt5i" said:THE TEACHER I DID AS YOU SAID IT NOW IT STARTED TO GIVE DIFFERENT ERRORS CAN YOU EXPLORE
