"izmirlimuhendis":kavo4ik5" said:
I have a problem in the project I have attached. I will be glad if you help.
Also, I don't know your architectural project and your obligation, but if I were you, I would make the S13 column like a p3 curtain. I would also remove column S14. Your ground safety tension is very good. Can't solve without doing the diagonal foundations? Try to make your beams the same size if it's not too much of a problem. I suggest you check your loads as well. Some of your beams and floors have loads of 1 tonne. In general, your column and beam sections are large. Unnecessary thickness on your floors gives weight to the system. Your concrete quality is also very good (C30) I think you may have made a mistake somewhere.
