HakanŞahin
Administrator
No, it's okay ... That value is the largest finite It means that finite element width can be used as much as the maximum entered value in wide areas and smaller finite element width in narrow areas."proisa":1k77z7bp" said:Do you mind if we enter a value greater than 25cm for the slab finite element width to make the solution faster when solving with a Semi-Rigid Diaphragm?
