HakanŞahin
Administrator
Re: ABOUT BEAM WIDTH 2
"zalman":u9ewgffr" said:FILE IS ADDED.
"zalman":1hlvmga6" said:HELLO FRIENDS... I AM ADDING THIS PICTURE DUE TO A BLESSING WITH THE MUNICIPALITY. HE DOESN'T CONFIRM THE PROJECT, CLAIMED THAT IT IS ATTACHED TO HIS FACE. THE IRON FROM THE BEAM REACHES TO THE OTHER SCREEN AND ACTUALLY GOES OVER THE SHORT SCREEN LIKE NEVER HAPPENED. The reinforcements extend up to P07 at the left end of the beam.
IT GIVES A REGULATIONAL ERRORS, ACTUALLY WE DON'T ATTACK THE ERRO, BUT THE FRIENDS IN THE MUNICIPALITY CAN SOMETIMES A PROBLEM. THANKS GOOD WORK..."HakanŞahin":2g6w33tk" said:The beam you are referencing, the reinforcements of K14 extend to the left end of P02 the reinforcements up to P07. There does not appear to be a problem with the beam opening."zalman":2g6w33tk" said:HELLO FRIENDS... I AM ADDING THIS PICTURE DUE TO A DIFFICULT WITH THE MUNICIPALITY. THE MUNICIPALITY DOES NOT APPROVE THE PROJECT, ALLEGING THAT A 67/32 BEAM STUCKED IN THE POLYGON CURTAIN IS ATTACHED TO THE 25 SIZE FACE OF THE SCREEN. THE IRON FROM THE BEAM REACHES TO THE OTHER CURTAIN AND ACTUALLY PASSES OVER THE SHORT CURTAIN LIKE NEVER. CAN WE GET COMMENTS FROM YOU VALUABLE FRIENDS? THANKS...
"zalman":1eijewmc" said:GIVES A REGULATORY ERRORS, ACTUALLY WE DON'T MAKE A FAULT HAKAN BUT FRIENDS IN THE MUNICIPALITY CAN MAKE A PROBLEM SOMETIMES.[THANKS] What do you call a regulation error?
BEAM HEIGHT+COLUMN FACE WIDTH TOTAL>BEAM WIDTH ERROR. I DID NOT TOLD IT TO GIVE THIS ERROR, ACTUALLY WE DON'T SEE IT AS AN ERROR."HakanŞahin":3cvrlnvk" said:What do you call regulation error?"zalman":3cvrlnvk" said:GIVES REGULATORY FAILURE, ACTUALLY WE DON'T FACE THE ERRORS, BUT HAKAN BUT CAN ASK THE MUNICIPAL BACK. THANKS GOOD WORK...
"zalman":2uh4gvzh" said:BEAM HEIGHT+COLUMN FACE WIDTH TOTAL>BEAM WIDTH ERROR. I DID NOT TOLD IT TO GIVE THIS ERROR. I ACTUALLY CAN'T SEE IT. ] If you ask my opinion, it depends on the length of the wall where the beam is defined and whether you will cut the reinforcement. In TDY it is written that the beam reinforcements can be extended and cut up to 50 ft in the wall, but it is not a mandatory condition. In your project, the length of the wall P02 is less than 50fi and the beam reinforcements are on the opposite wall, P07 and the rebars are curved into the curtain. The beam is supported on both P02 and P07. Therefore, the width control you mentioned may be ignored for this combination.
THANK YOU VERY MUCH WE CAN SHOW THIS AS A REFERENCE GOOD WORK..."HakanŞahin":3r14n0ra" said:If you ask my opinion, it depends on the length of the wall where the beam is defined and whether you cut the reinforcement. It is written in TDY that beam reinforcements can be extended and cut by 50 ft in the shear, but it is not a mandatory condition. In your project, the length of the P02 curtain is less than 50fi and the beam reinforcements extend up to the opposite curtain, P07, and the reinforcements are curved into the curtain. The beam is supported by both P02 and P07. So the width control you mentioned may be ignored for this join."zalman":3r14n0ra" said:BEAM HEIGHT+COLUMN FACE WIDTH TOTAL>BEAM WIDTH ERROR. I DON'T TOLD IT TO GIVE THIS ERROR, ACTUALLY WE DON'T SEE IT AS AN ERROR.
Hello, I had to delete and reinstall the program and I am getting this error in all my projects. Is there any solution to this problem other than copy to file and paste from file?"Levent Özpak":3mu1me4v" said:Hello, If the drawing sheet is moved to another project file using the "Copy to file" and "Paste from file" commands, it can be exported. The exportable sample is attached. Note: The export problem is related to the line type, fonts, etc. in the content of the dwg file imported to the project. may be due to reasons. Could you send the dwg file you imported to [email protected]? Also, do not use the settings of this project file in another project. You will encounter the same problem. Good work"nitasltd":3mu1me4v" said:https://drive.google.com/open?id =1fkA7I7PbOfh1Q9E6lvOpIIQ1VVrl5a3Z I keep getting an error while exporting the hello layout from my file
Hello, There is a separate sheet for piles in the reports. concrete and steel class is not displayed.For now, I would suggest adding a page to the report and adding the material information in the analysis model to this page in picture format."s_f_d":1ttv6t86" said:Hi, I could not find the concrete class steel class values used in piling in the Pile reinforced concrete calculations. Is there a point I missed? Where can I see it? Sent via iPhone using Tapatalk
