HakanŞahin
Administrator
Re: Opinions about using ideCAD Reinforced Concrete 8 questions
Hello, Adjust the dome supports together with the structure according to the solution. After adjusting the supports and analyzing, you will be able to get a drawing. If you make a solution independent of the structure, you need to enter the reinforcement until the missing aces are corrected in the dome reinforcements in order to get the dome drawing. You can then get the drawing without closing the program."mgondem":1lsui1qx" said:1.In my attached project, even though I do dome analysis, reinforcement selection is not made. When I want to draw a dome, the program closes.
I could not create such a situation on my own computer. If you call our Bursa office during working hours, we can look at the situation you have reported by connecting to our computer with remote access."mgondem ":1lsui1qx" said:2. Although the ribbon menu is closed, the ribbon menu becomes active again after I open a project made while the ribbon menu is open.
