Ismail Hakki Besler
Administrator
Opinions and questions about using ideCAD Reinforced Concrete 8
Hello, 10' reinforcement is the ampatment distribution reinforcement. We can change the diameter of the reinforcement in the basic parameters all the time."ofis2a":396mvlr6" said:In ideCAD 8, it constantly shows the 10-gauge reinforcement for continuous foundations in the reports even though I did not mark it in the diameter selection. I was having this problem. Also, although it is not in any position in the detailed quantity, there is 10 reinforcements in the total quantity report. Good work...
The reinforcements in the Torsion tab are automatically calculated according to the torsion calculation and show the number and diameters of the reinforcement added to the section. Here, the information on how much is required is given, otherwise it is printed blank, otherwise the existing reinforcement If this reinforcement is provided along the beam, the program does not give inadequacy in terms of torsion reinforcement."proisa":17x41bse" said:Hello, how is the torsion reinforcement section used in the torsion tab of the reinforced concrete section beams? -middle-bottom) is empty and no action can be performed.
Hello, We did not see such a problem. Could you add an example?"Oznb":28eoccvd" said:1- When changing the size of the columns, where I define the enlargement limit, enlargement is made, but while shrinking, the program does it on the other hand. It would be great if an arrangement could be added to accept the node as fixed.
"Oznb":3icqapdm" said:In the pile detail drawings, the upper level of the foundation is accepted as 0.00.(level at normal floor settings -5.80), can you check ?[/quote ] Thank you for your report.
Hello, This situation is recorded in our notes. Currently, the number of stirrups appears in the Column Application Plan In the Settings/Advanced Settings Tab, it is enough to tick the "Draw reinforcement pose numbers" option once or uncheck it if it is checked."SKUSCU":evxghoy8" said:Hi, first of all, I would like to congratulate you for your work, indeed the ide family has made great progress. and I wanted to share them with you to find out if the problem is from the data entry or a program error 1.) The number of stirrups appears as 0 in the column application plans.
We did not create this situation you mentioned. curtain crosses appear in curtain details Can you add a sample drawing of the problem? We can also examine the problem by providing remote access to your computer with the amviwer program.2.) Curtain crossties are not visible in column application plans and curtain vertical expansions.
The problem has been recorded in our notes. In this version, you can delete the tie beams and get the basement beam extensions. Thank you for your notifications. Note: The continuous foundations defined under the panels such as P2-P3-P4-P10 are not connected at the nodes of the panels. Good work3.) The program crashes and closes while retrieving basement beam extensions. ( Encountered in 2 different projects )
We did not create this situation you mentioned. In the drawings we received, the curtain crosses appear in the curtain details. Can you add a sample drawing of the problem? If necessary, we can examine the problem by providing remote access to your computer with the teamviwer program. I am sending the related drawing as attachment. I also wanted to give information about a few issues 1.) The project file gives an error when taking quantities and closes. ( Encountered in 2 different projects ) 2.) When saving the project, instead of recording on the same backup file, it keeps recording different bak files. 3.) I could not find the ENDPOINT EDIT command that I use in general, in the new version.2.) The cross-ties of the curtains are not visible in the column application plans and vertical openings of the curtains.
"SKUSCU":36eli2l4" said:2.) When saving the project, instead of saving on the same backup file, it keeps recording different bak file. Due to the current version, my friends thought this way. I guess for ease of debugging. Also, only data is stored in these bak files, there are no drawings for your attention...+10"SKUSCU":36eli2l4" said:3.) ENDPOINT EDIT, which I use in general, is useful I couldn't find the command in the new version.
] Hello Mr. Sabahattin, There are curtain crossties in the drawing you marked. According to TDY 2007 article 3.6.3.3, it is sufficient to put 10 crossties along the critical curtain height in the middle of the curtain, and 4 crosses outside the critical curtain height. Therefore, a change was made in the 8 version compared to the 7 version. However, this statement of yours has been included in our notes for consideration."SKUSCU":3dryxhoy" said:Hello Mr. Levent, thank you for your interest and suggestions.We did not create the situation you mentioned. In the drawings we received, the curtain cross-ties appear in the curtain details. Can you add a sample drawing of the problem? If necessary, we can examine the problem by remote access to your computer with the teamviwer program. I am sending the drawing on the subject as an attachment.2.) In column application plans and vertical openings of curtains, The crossties are not visible.
Saved in our status notes. Good workWhile taking the project file quantity it crashes and closes. ( Encountered in 2 different projects )
