library problem
akif tekin
hello, the dimensions of the library I want to use in the plan and the dimensions in 3 dimensions are different. The dimensions in the plan are 28x15, when I enter the library properties, the dimensions are 7x3
Download the attached basketball court A.ktp2 file and paste it into Computer/Local Disk(C)/Program Files/ideCAD/ideCAD Architecture/Libraries/Indoor and outdoor sports equipment directory. Open ideCAD Architecture7 and select the ktp2 you pasted from the library. In its settings, change the Dimensions/X length, Y length parameters as desired. Or, you can do the same replacement with the percentage parameters.
Greetings, Mr. Akif, if you send an e-mail to [email protected] that you have found to be incorrect, we will correct it as soon as possible and send it to you as well as put it in the intallation as corrected. Thank you also for your report.
